CKP sensor please help!
Old Jan 11, 2005 | 03:55 PM
G2Crash's Avatar
Default CKP sensor please help!
Alright, I just swapped my gsr motor back in my integra. started it up. drove it around the block for about 10 minutes, drove fine but sluggish.
I"m getting a code 7 and 4. and I'm running obd-0 everything
Code 4 is what I'm stuck on and what I need help with.
I replaced the distributor with another working one and it's doing the same thing, will occasionally start but dies right away and it throws the code.
I reset the ecu a few times, it didn't help, I looked at everything and it all looks right and plugged in good and tight. I cracked open the ecu and that looks fine too.
I"m lost, and I need help with this pretty bad. please reply, or my msn and aim is G2Crash@aol.com. TIA
Old Jan 12, 2005 | 04:18 AM
JimBlake's Avatar
Default Re: CKP sensor please help! (G2Crash)
Well, if you've tried a new distributor, then what's left is to check the wiring from there to the ECU. On my '95 the CKP sensor wires are blue/green(shielded) & blue/yellow. (But I don't know if they used the same colors on earlier years?)
Old Jan 13, 2005 | 01:33 AM
G2Crash's Avatar
ya I'm pretty sure they are different colors, I'm going to try another wire harness and see if that helps. Thanks for the reply.
dubs97integ
Mar 9, 2009 10:31 PM
oldschoolfreak
Mar 25, 2005 06:18 PM
fast-rex
Jan 28, 2003 01:35 PM
fast-rex
Jan 27, 2003 04:53 AM
