Some LS-Vtec Questions...
Old Jan 11, 2005 | 01:16 PM
No's Avatar
No
Default Some LS-Vtec Questions...
I was just wondering where you guys purchased a thinner than stock headgasket?I heard about this raising the compression,on c-speedraing.I almost got too about a .4 increase in compression with just the headgasket swap.I know it retards your timing,but would it be that much where you couldnt fix it because of the distributor timing?Also I was just looking at someone else's build and they said they bought a gsr cable throttle?Is this necessary or can i re-use my ls one?Can i also reuse my stock ls injectors and everything on the intake manifold?Thank You
Old Jan 11, 2005 | 03:18 PM
No's Avatar
No
Also my vtec solenoid is cut.Where the plug is...its just a green wire hanging.And the oil pressure connector seems too be broken.Anyone know if i can rebuild it?Just hardwire the vtec wire too the green wire on the solenoid,maybe replace the pressure switch?
Old Jan 16, 2005 | 09:25 PM
LSRracing95's Avatar
Default Re: Some LS-Vtec Questions... (narib2oo1)
yes, you can re-use the LS injectors.. its actually better that you do.. all b-series injectors flow at about 240cc. you can also use LS fuel rail and throttle body etc.. you do however, need to change over to a b-series VTEC intake manifold (b18c or b16a). i am planning on doing LS/VTEC myself and have researched for months now on what to do and what not to do. so any questions, i should have an answer for ya..
Old Jan 16, 2005 | 09:27 PM
...also, a thinner headgasket will raise compression because it will lower your overall height of the cylinder head.. and as far as your VTEC solenoid, id probably search for another..
Old Jan 16, 2005 | 09:29 PM
..jesus i need to put this all in one post haha, another thing on your headgasket question, it will retard your timing slightly.. but that is nothing a set of cam gears and a dyno cant take care of as far as i know..
91 DA Revived
Oct 28, 2010 05:25 PM
civicguy81
May 23, 2006 03:33 PM
HarryB
Jul 4, 2002 11:58 AM
