Timing light flash question
Old Jan 12, 2005 | 02:04 AM
Dark_Helmet's Avatar
From: A redder shade of neck on a whiter shade of trash
Default Timing light flash question
No need for all the "kill 05 members" posts, I've been on here since 2002 but I lost my password and had to make a new acct
Anyway- When using a timing light aimed at the crank pulley, what does it mean when each flash isn't *exactly* where the previous flash is? Only thing I can think of is a shot distributor cap/rotor...
To better explain the situation, here is a diagram:
| <---Rotation one
| <---Two
| <---Three
| <--Four
Each vertical line is 16 deg BTC marks on pulley, the first one is the first revolution, the second is the next, etc. The asterisk is where the flash from the timing light, except it would be like 1 degree or so before or after the previous one.
Any ideas?
Old Jan 12, 2005 | 04:15 AM
Ri5e's Avatar
Default Re: Timing light flash question (Dark_Helmet)
What kind of timing light gun are you using? Mine does the same thing (It's never *exactly* at the 16 BTDC mark)
Old Jan 12, 2005 | 05:47 AM
JimBlake's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dark_Helmet &raquo;</TD></TR><TR><TD CLASS="quote">Any ideas? </TD></TR></TABLE>I think you got owned by the BB software which collapses the white spaces & makes it look like they all line up perfectly... So how far off are they really? As much as 1 or 2 degrees?
If you don't jumper the SCS connector, your ECU is always making little adjustments to timing. Maybe that's part of it?
If the distributor shaft bearing is getting sloppy, or your timing belt is getting loose or sloppy, that can also do it. That means your timing is truly moving around.
Last, if you've got a timing light with a delay/advance control, maybe it's flaky??
Old Jan 12, 2005 | 05:51 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Always make sure the car is at full operating temperature and the ECU is in diagnostic mode (jump the diagnostic connector w/ a wire or paper clip, same as when checking for trouble codes) before using a timing light. Diagnostic mode keeps the timing fixed so you can check and adjust it. During regular idling or driving the ECU continually adjusts timing slightly so the engine will run its best.
I just bought a timing light last week and adjusted my timing (the distributor had worked its way over to fully advanced over the course of the last 100K miles since it was last checked ) and I had no problems at all getting it set.
david90
Nov 18, 2003 10:09 AM
wantmorepower
Apr 16, 2003 09:52 PM
Accord94DX
Dec 1, 2002 12:59 AM
illusion
Feb 16, 2002 11:18 AM
JSpecwest
Aug 25, 2001 07:23 PM
