icm, (ignitor) voltage
Old Jan 10, 2005 | 10:56 AM
jtracing919's Avatar
Default icm, (ignitor) voltage
b18c, what should the voltage be coming out of the ecu to the siganl wire to the icm?
Old Jan 10, 2005 | 12:15 PM
Default Re: icm, (ignitor) voltage (jtracing919)
does the ecu send a signal(voltage) to the icm or what makes the coil fire?
Old Jan 11, 2005 | 03:08 AM
JimBlake's Avatar
Default Re: icm, (jtracing919)
I'm not completely sure, but I think the ECU connects & disconnects that wire to ground to fire the ignition.
Old Jan 11, 2005 | 06:41 AM
Default Re: icm, (JimBlake)
how can i check to see if the ecu is sending the signal to ground the coil, to make it fire?
93cavRS
Oct 10, 2006 12:25 PM
jtracing919
Jan 11, 2005 06:45 AM
AndyD
Jun 3, 2004 04:38 AM
CimorelliCRX
Sep 21, 2002 02:20 PM
