HELP!!!
Old Jan 10, 2005 | 11:06 PM
inew's Avatar
Default HELP!!!
hey guys, jus bought a jdm integra with 160hp. can the K20 take ITR K20A cams n valves cam gears???? pardon my ignorance. but else do i need to change in order to lift the performance to ITR level.
Old Jan 11, 2005 | 03:39 AM
JimBlake's Avatar
Default Re: HELP!!! (inew)
K20 in an Integra? What year? You're not in USA, right? In USA the 4th-gen Integra is called RSX. Try the RSX forum for better answers...
Old Jan 11, 2005 | 06:23 PM
Calsonic's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by inew &raquo;</TD></TR><TR><TD CLASS="quote">hey guys, jus bought a jdm integra with 160hp. can the K20 take ITR K20A cams n valves cam gears???? pardon my ignorance. but else do i need to change in order to lift the performance to ITR level. </TD></TR></TABLE>
*edit*
Modified by Calsonic at 12:12 AM 1/12/2005
Old Jan 11, 2005 | 06:55 PM
b-power's Avatar
sounds like he is a little confused
Old Jan 11, 2005 | 07:29 PM
BremertonDA's Avatar
From: Bremerton, Washington, United States of America
You sure he's confused?
Old Jan 11, 2005 | 07:40 PM
Ok boys, pulled these specs off T-I.net:
Model iS Type R
Engine Code K20A
Engine Type 2.0L, 4 cylinder, DOHC i-VTEC
Valvetrain 16 valve, 4 valves per cylinder, dual overhead camshafts, intelligent variable valve timing and lift with electronic control, chain driven
Power
160 PS (157 HP) @ 6500 RPM
220 PS (216 HP) @ 8000 RPM
Torque
19.5 kg-m (141 lbs-ft) @ 4000 RPM
21.0 kg-m (152 lbs-ft) @ 7000 RPM
Bore x Stroke 86mm x 86mm
Displacement 1,998cc
Compression Ratio 9.8:1 11.5:1
Fuel System Electronically controlled fuel injection (PGM-FI)
Ignition System Electronic Ignition
Powertrain Transverse front engine, front wheel drive (FF)
The JDM K20 comes in 160hp (:
Old Jan 11, 2005 | 07:58 PM
Calsonic's Avatar
Default Re: (BremertonDA)
If he has a K20A3 Civic Si / RSX i-VTEC motor than he can't use K20A2 (RSX Type-S) or K20A (ITR) cams.
Modified by Calsonic at 12:30 AM 1/12/2005
Old Jan 11, 2005 | 11:36 PM
inew's Avatar
Default Re: (Calsonic)
hi there....jus found out that my car is the RSX not the type S....i'm in south asia....so i can't use the ITR/Type S cams???what a pity....in that case, what can i do to improve the performance????thks
Old Jan 11, 2005 | 11:38 PM
Sack Master's Avatar
Default Re: (inew)
As stated you may have more luck in the RSX forum.
Old Jan 12, 2005 | 04:08 AM
JimBlake's Avatar
Default Re: (inew)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by inew &raquo;</TD></TR><TR><TD CLASS="quote">...i'm in south asia...</TD></TR></TABLE>So your car is called an Integra, but here in USA it's been re-named as the RSX.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b-power &raquo;</TD></TR><TR><TD CLASS="quote">sounds like he is a little confused</TD></TR></TABLE>Didn't you know that the RSX is called the (4th-gen) Integra everywhere but here?
Old Jan 12, 2005 | 06:56 AM
Calsonic's Avatar
Default Re: (inew)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by inew &raquo;</TD></TR><TR><TD CLASS="quote">hi there....jus found out that my car is the RSX not the type S....i'm in south asia....so i can't use the ITR/Type S cams???what a pity....in that case, what can i do to improve the performance????thks</TD></TR></TABLE>
The cams won't work from the ITR or Type-S. What you can do is swap the head from an ITR or Type-S and add an oil-cooler and metal headgasket.
vtec770
Jul 23, 2007 09:28 PM
drumminforev
Oct 13, 2006 12:38 PM
8krdline
May 10, 2005 12:19 PM
Antilag
Jan 29, 2005 04:10 PM
SLOAZZ95
Sep 14, 2004 11:39 AM
