GSR cluster on LS
Old Jan 10, 2005 | 03:09 PM
DsBananas94LS's Avatar
Default GSR cluster on LS
just to make sure that A Gsr cluster would be fine on a LS and the revs would be accurate. I know i will still redline a 6900 that is only for now.
Old Jan 10, 2005 | 03:43 PM
Honduh Chicken's Avatar
I fry gay turkeys
Default Re: GSR cluster on LS (DsBananas94LS)
Should be fine, I used a hype-r cluster on myh LS and everything worked fine. plug n play babee.
Old Jan 10, 2005 | 07:55 PM
RaNMaN's Avatar
sure it will work.. i switched OBD's with mine so i had to pop out the individual gsr gauges and install them in the LS cluster for all the accessory lights to work, but it works great.. i went ahead and chipped my ECU when i went turbo and changed the rev limiter to 8K even though i hardly ever take it up that high.. good mod, get on it!!
Old Jan 10, 2005 | 08:30 PM
chero112's Avatar
Default Re: GSR cluster on LS (RaNMaN)
not sure I think a 00-01 gsr cluster wont work in a ls but the older one's would... my 2 cents
SweetChinMusic
Feb 18, 2013 08:26 AM
rick_rabies
Jun 22, 2009 11:31 AM
dc2much
Mar 15, 2008 02:46 PM
Boofster
Jan 5, 2004 02:06 PM
flat-blk-HB
Oct 31, 2003 08:05 PM
