Idling Question
Old Sep 18, 2005 | 07:31 PM
Corporation's Avatar
Economic Upturn, WUT
From: Alittle Placed Called None of Your Damn Business.
Default Idling Question
When I first start my car in the morning the car jumps to 2k RPM~ and it sits there for awhile, it takes it probably 10 minutes for it to go back down to 750-1000. How do I fix this?
Old Sep 18, 2005 | 07:44 PM
White GSR '01's Avatar
Default Re: Idling Question (ahrpr)
when you start your car and the engine is cold it will normally idle higher than when the engine is warm.
Old Sep 18, 2005 | 07:46 PM
Default Re: Idling Question (White GSR '01)
So it will be normal for it to idle kind of high for a while before going down?
Old Sep 18, 2005 | 07:49 PM
Is your check engine light on?
Old Sep 18, 2005 | 07:51 PM
Chewie's Avatar
its normal for higher idle when engine is cold, if you do have ot drive, try it keep it under 3k until the engine is warm
Old Sep 18, 2005 | 07:54 PM
If your check engine light is on go to autozone and have them read your ecu. They do it for free. IF something is wrong then it would probably be your idle speed sensor.
If you don't have the CEL on then there is nothing wrong and just wait for the engine to warm up before givin it hell.
Old Sep 18, 2005 | 08:02 PM
SuzukaBlueAP2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ahrpr &raquo;</TD></TR><TR><TD CLASS="quote">So it will be normal for it to idle kind of high for a while before going down? </TD></TR></TABLE>
Completely normal. There is a valve that opens when you start your engine cold, allowing more air in, thus raising the revs. Until your fluids are up to temp., the engine stays at a higher rpm and gradually descends.
Old Sep 18, 2005 | 08:40 PM
no cel and I know how to figure them out. I think it is because its cool in the morning.
Old Sep 18, 2005 | 10:38 PM
9hatch2's Avatar
Default Re: Idling Question (ScreaminTeg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ScreaminTeg &raquo;</TD></TR><TR><TD CLASS="quote">
Completely normal. There is a valve that opens when you start your engine cold, allowing more air in, thus raising the revs. Until your fluids are up to temp., the engine stays at a higher rpm and gradually descends. </TD></TR></TABLE>
MisterTea
Dec 19, 2013 08:56 AM
stefanne3
Jan 29, 2007 09:18 AM
cchev
Jan 23, 2004 04:00 PM
PiYoImuT
Sep 7, 2001 09:08 AM
