throttle problem?
Old Sep 20, 2005 | 07:44 PM
jizzer671's Avatar
Default throttle problem?
On the way to work i was in fith gear doing 45mph. I just gave the throttle a little push to pass a car and then my throttle gets stuck. my foots off the throttle and its still acceling. i had to retracked the pedal back with my foot to decel the gsr. how do i fix this problem.
Old Sep 20, 2005 | 07:47 PM
Chewie's Avatar
Default Re: throttle problem? (valve timer)
is it still doing the same thing?
Old Sep 20, 2005 | 08:55 PM
Hustla's Avatar
Old Sep 21, 2005 | 06:46 AM
jizzer671's Avatar
I can still go easy on the throttle and drive it without it getting stuck but when i want to floor it it does the samething...
Old Sep 21, 2005 | 06:59 AM
MrAngry's Avatar
wd40 on the throttle bracket. check the tension. might need to replace it.
45 on a highway isnt scary.. 50 and rising through a narrow parking lot full of cars with multiple dividers is.
hahaha. my old gsr was a deathtrap.
Old Sep 21, 2005 | 07:01 AM
jizzer671's Avatar
Could it be the throttle cable?
Old Sep 21, 2005 | 07:07 AM
jizzer671's Avatar
I will use the wd40 and if the problem continues I will replace thanx.
Mcdc2
Feb 3, 2009 02:30 PM
shabam
Dec 9, 2007 07:52 PM
Nameless Warrior
Feb 1, 2007 08:58 AM
1QWKGS
Apr 3, 2005 11:52 PM
