maintance required light
Old Sep 18, 2005 | 08:02 PM
OwnsAnAcura's Avatar
Default maintance required light
wat exactly falls under the maintance required, im not sure what is wrong and im always so busy i never really have time to look into it. my oil is fine and my oil light isnt on... i think i remember hearing that it mite be mechinally driven by the milage or wat not and u jus have to reset it. only thing i cud think of is my slave and master cylinder are about to give out and im jus waitin on the master to come in so i can install it, but i wudnt think the light would be on because of that... answers?
Old Sep 18, 2005 | 08:06 PM
SuzukaBlueAP2's Avatar
Default Re: maintance required light (OwnsAnAcura)
The maint. req'd light is on a timer basically. At certain mileages on the odometer, it comes on to remind you to take it to the dealership to have routing manitenence performed on the vehicle. These actions include oil changes, all other fluid changes, tire rotation, timing belt change, etc.
If you keep up with your own stuff and know when to replace worn parts, you can reset it yourself. There's a button underneath the driver's side dash that you hold in.
Old Sep 18, 2005 | 08:08 PM
thats wat i was thinking... all the maintance was done at 90,000 miles and i jus changed the oil about 3,000 miles ago.. the car has 113,000 miles. but thats wat i was thinking, im jus going to reset it myself.... thanks
Old Sep 18, 2005 | 10:08 PM
DynastyRacer22's Avatar
you should check this out
http://www.acuraofbellevue.com...chtml
Shaun
Acura TL, RL & ZDX
Dec 27, 2006 03:31 PM
luvinmyGSR
Feb 18, 2004 05:19 AM
integra81
Apr 13, 2002 09:55 AM
Seedc2
Aug 18, 2001 08:01 PM
Ibuprofen
Jul 1, 2001 08:07 PM
