need help please
Old Sep 18, 2005 | 05:39 PM
Integra8847's Avatar
Default need help please
I have a 1996 supercharged integra ls the past month or so in 5th gear giving it partial throttle it would sputter a little bit. but only sometimes like 1 time a week or so. well it had been sputtering alot more this weekend and on the way home i was pulling up to a stop light and took it out of gear and it died. It will turn over but wont start. i still have power to everything so i was thinking maybe fuel related. pump or filters....what do you guys think?
Old Sep 18, 2005 | 05:42 PM
DAguyLS's Avatar
Default Re: need help please (Integra8847)
look into your dizzy, and make sure everything is up to par.
Old Sep 18, 2005 | 05:46 PM
Default Re: need help please (DAguyLS)
i was thinking that also...i checked it and it seemed to be getting spark thats why i was thinking fuel prob
Old Sep 18, 2005 | 06:01 PM
teggy182's Avatar
to start i'd say just check the connections to the injectors and pump.
Old Sep 18, 2005 | 07:52 PM
BUMP
Old Sep 18, 2005 | 08:08 PM
SuzukaBlueAP2's Avatar
what do you mean "it seemed to be getting spark"? It either is or it isn't. Test your distributor for sure. If there's not spark, you have an ignition related problem. If you do have spark, then you can look at other things. Do a compression test. Make sure everything is still healthy.
lovemyhonda17
32
May 27, 2011 07:32 PM
krazn
Dec 5, 2005 10:02 AM
stunt_driver
Jun 8, 2005 04:55 AM
Honda Hick
Feb 28, 2005 09:20 AM
BeavisB16
Jul 27, 2003 11:30 AM
