what is the voltage on a knock sensor.
Old Sep 18, 2005 | 03:33 PM
FunIntegras's Avatar
Default what is the voltage on a knock sensor.
Hi, I would like to know whats the voltage of the knock sensor when there is no knock.
THanks
Hope someone can help
Old Sep 20, 2005 | 12:36 PM
shamoo's Avatar
Will you make something up for me please?
Default Re: what is the voltage on a knock sensor. (FunIntegras)
Subscribed so I can check my Helms when I get home.
Old Sep 20, 2005 | 12:43 PM
2G0S0R1's Avatar
New User
Default Re: what is the voltage on a knock sensor. (shamoo)
Dig through here and you'll find it... I love my Helms but it would be nice if it had a badass index, haha.
http://www.redpepperracing.com...a-FSM
Old Sep 20, 2005 | 03:02 PM
shamoo's Avatar
Default Re: what is the voltage on a knock sensor. (2G0S0R1)
I just spent like 20 minutes looking through my Helms.
It doesn't say much. There's an entire page (11-77) devoted to the knock sensor troubleshooting, but it doesn't tell you voltage. Let me know and I can type that page out for you.
The other page (11-37) describing the ECM pins shows that the knock sensor should read a pulsing signal on a multimeter (while the engine is running). It's strange because for every other sensor, it tells you the voltage. I'm gonna make a guess based on the other sensor readings that it should pulse between 0V and 5V.
Old Oct 1, 2005 | 01:19 PM
Under_Pressure's Avatar
here u go.
Listed below is honda's table for appropriate knock noise @ WOT
__RPM Knock Sensor __Voltage(Volts)
0 0.01953125
800 0.01953125
1600 0.01953125
2400 0.05859375
3200 0.29296875
4000 0.7421875
4800 1.23046875
5600 1.71875
6400 2.2265625
7200 2.71484375
8000 3.22265625
8800 3.7109375
9600 4.140625
10400 4.609375
11200 4.98046875
12000 4.98046875
12800 4.98046875
Old Oct 1, 2005 | 01:23 PM
Chewie's Avatar
Default Re: what is the voltage on a knock sensor. (92h22alude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92h22alude &raquo;</TD></TR><TR><TD CLASS="quote">
9600 4.140625
10400 4.609375
11200 4.98046875
12000 4.98046875
12800 4.98046875 </TD></TR></TABLE>
how are those numbers achieved? were they guestimates?
Old Oct 2, 2005 | 06:00 AM
Default Re: what is the voltage on a knock sensor. (Chewie)
built engine. this was done by AEM.
