tire rubbing problem
Old Sep 20, 2005 | 09:43 AM
boosted94teggy's Avatar
Default tire rubbing problem
hey i have a 94 ls and right now on my car i have 215/50/17 tires on it and i have stock suspension the car rubs when there is another person in the car but only when i turn if i get new coilovers and struts(stock struts tho but no gas leaks) and if they are tight and have front rear and under strut bars do u think it will still rub? thanks for comments
Old Sep 20, 2005 | 11:32 AM
cm zak's Avatar
Do both front tires rub? or just one?
Old Sep 20, 2005 | 12:38 PM
low430's Avatar
Default Re: tire rubbing problem (boosted94teggy)
50 series on 17" rims is too big for your car, Get smaller tires
Old Sep 20, 2005 | 12:44 PM
2G0S0R1's Avatar
New User
Default Re: tire rubbing problem (low430)
yup... you need 40 or 45 series, the 215 is getting you too.
Old Sep 20, 2005 | 12:50 PM
temp's Avatar
Default Re: tire rubbing problem (2G0S0R1)
dont slam it so low
Old Sep 20, 2005 | 12:58 PM
SYTFU Tommy.'s Avatar
Default Re: tire rubbing problem (temp)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by temp &raquo;</TD></TR><TR><TD CLASS="quote">dont slam it so low </TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boosted94teggy &raquo;</TD></TR><TR><TD CLASS="quote">hey i have a 94 ls and right now on my car i have 215/50/17 tires on it and i have stock suspension the car rubs when there is another person in the car but only when i turn if i get new coilovers and struts(stock struts tho but no gas leaks) and if they are tight and have front rear and under strut bars do u think it will still rub? thanks for comments</TD></TR></TABLE>
how can he slam it low on stock suspension. its jsut his tires size as stated above by others.
Old Sep 20, 2005 | 01:07 PM
temp's Avatar
Default Re: tire rubbing problem (tngay)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tngay &raquo;</TD></TR><TR><TD CLASS="quote">
how can he slam it low on stock suspension. its jsut his tires size as stated above by others.</TD></TR></TABLE>
shhhhhhhhhhhhh i said dont slam it low
reallycooleg
May 25, 2007 07:34 AM
civic_66
Apr 17, 2007 06:09 AM
vtecjb
Dec 13, 2006 05:54 PM
dt4life
May 16, 2006 09:42 PM
jromulo
Suspension & Brakes
May 29, 2005 04:36 PM
