Lower ball joint spinning?
Old Sep 19, 2005 | 01:41 PM
MNsnowdaboy's Avatar
Default Lower ball joint spinning?
Ok so here I go with the new project but first comes already when I'm trying to tighten the castle nut on the lower ball joint. The whole lower ball joint is spinning, does this mean it's shot? Do I need a new replacement ball joint? Also how much do I need to remove so I can press it out, lucky my dad has a press machine.
what's the average price for lower ball joints and best place to buy it.
Any help would be appreciated.
Old Sep 19, 2005 | 02:21 PM
CBURKE's Avatar
don't know the price but yes it is shot!!!
Old Sep 19, 2005 | 02:23 PM
BlackLudeSi's Avatar
Default Re: (CBURKE)
No not really, it can mean they are bad but I have done many that were not and spun. Just get a real big pair of pliers and just squeeze the spindle and the lower arm together.
Old Sep 19, 2005 | 05:01 PM
TODA GS_R's Avatar
no its not shot! the ball joints actually tapered so the more you squeeze them together like the guy sed above....then you sure be good. if anything...support the lca with a brick, jack or whatever...then have another person put all their fat *** weight on the spindle...and try it! good luck
Old Sep 19, 2005 | 05:41 PM
LSvtec03's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CBURKE &raquo;</TD></TR><TR><TD CLASS="quote">don't know the price but yes it is shot!!!</TD></TR></TABLE>
NO, that does not mean it's shot. have someone put some weight on top of it while you tighten it.
Old Sep 19, 2005 | 05:54 PM
hamburgler's Avatar
Default Re: (LSvtec03)
i looked them up today and i found somewhere on google by typing in integra ball joint that was selling 2 for like $36 for a 94-01
Old Sep 19, 2005 | 05:55 PM
hamburgler's Avatar
Default Re: Lower ball joint spinning? (MNsnowdaboy)
here i found it again for u
http://www.pitstopparts.com/di....html
Old Sep 20, 2005 | 03:52 PM
I tried having sombody using pressure and a clamp but no luck. That sucka is just spinning freely, rusted up threads aren't helping either.
It's hard for me to believe that the ball joint isn't shot, it's not design to spin is it??? I've never heard of this happening to the newer cars.
Ok questions about all these unheard of websites that carries these OEM replacements. Are they a big buisness or somebody just selling off his trunks and can afford a website. I hate buying from ebay and kids with license to have a buisness, get what I'm saying.
anyways thanks.
Old Sep 20, 2005 | 04:49 PM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Yes ball joints are made to spin, that's what they're there for, so that the suspension can turn as you steer the wheels and the suspension moves up and down at the same time.
Are you trying to REMOVE the castle nut or put it back on? Take a floor jack or scissor jack and place it under the LCA and start raising it up. Raise it until that corner of the car just about ready to come off the jackstand. That means the full weight of the car is on that corner, and the LCA and spindle will be pressed together. Now try to remove or tighten the nut. Some PB Blaster on the threads might help, also.
Also if you're trying to tighten the nut, remove it first and clean off the threads with something like a Dremel with a wire wheel bit.
Old Sep 20, 2005 | 04:57 PM
Default Re: (PatrickGSR94)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PatrickGSR94 &raquo;</TD></TR><TR><TD CLASS="quote">
Are you trying to REMOVE the castle nut or put it back on? Take a floor jack or scissor jack and place it under the LCA and start raising it up. Raise it until that corner of the car just about ready to come off the jackstand. That means the full weight of the car is on that corner, and the LCA and spindle will be pressed together. Now try to remove or tighten the nut. </TD></TR></TABLE>
Trying to put it back.......
Oh I see, ok I'll try that next, maybe I just might not have to spend that extra 40 bucks on new ball joints..
Ef4doorwagon
Nov 21, 2014 03:47 PM
Kevins89notch
21
Nov 4, 2013 06:17 AM
halocore
Mar 7, 2009 04:34 PM
civicboisi
Jun 6, 2004 01:27 PM
97hb
Mar 9, 2002 11:31 PM
