how?
how do i turn on my high beem without turning on the regular headlights? because im planning smoked yellow high beem and use them in day and use both (regular and high) at nightt. please help me out. thank you post some pics would help alot.
Okay first your talking about your high beams not your brights right. Okay open up the headlight switch bar. In there you will see that there is three connectors. One is for the lows one is for the highs and one is for hte brights. Take the connector of for the highs and run that wire to a separate switch to mount on your dash. Thats it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by integradude98 »</TD></TR><TR><TD CLASS="quote">Okay first your talking about your high beams not your brights right. Okay open up the headlight switch bar. In there you will see that there is three connectors. One is for the lows one is for the highs and one is for hte brights. Take the connector of for the highs and run that wire to a separate switch to mount on your dash. Thats it. </TD></TR></TABLE>
What kind of car do you have with three headlight settings? The three switches are for your corner lamps and tails, then the low beams, and then the high beams, which are the brights.
i wish i had brights and high beams
creepy116
Nov 30, 2006 05:12 AM
