Engine swap, Injector problems
Old Feb 28, 2006 | 05:51 PM
Guldan's Avatar
Default Engine swap, Injector problems
I have a 91 teg, blew the engine, replaced it, realized i bought a trash engine, removed it.......
and now, 6 months later, i finally found a replacement engine and the money to replace it......
everthing is great, except the injectors, they need more ohms, or i need a new ecu...... (really don't have the money for that right now)
is there any way to boost the ohms going to the injectors, like to replace the resistor box (no clue what it does, so no clue if it would work) or do i need to find some 91 injectors and lose my extra 10 hp?
any help is greatly appreciated
Old Feb 28, 2006 | 06:50 PM
ImportMotorSpec's Avatar
Default Re: Engine swap, Injector problems (Guldan)
Need a little more info. What year was teh motor that you put it. Did you use your stock injectors and somthing went wrong or did you use the ones from the new motor? Did you change ecu or is it running the stock ecu.
Old Mar 1, 2006 | 06:19 AM
Guldan's Avatar
the engine in there now is a 93, the previous engine was a 92, my stock injectors are probably crushed by now and the ecu is stock
FOXxX
45
May 1, 2012 06:52 PM
frostwhite_92
Engine Management and Tuning
Nov 12, 2011 12:33 AM
toeknee360*
Sep 26, 2005 10:09 PM
satan_srv
Aug 20, 2002 12:02 PM
