Questions about Performance Chips
Old Mar 1, 2006 | 04:43 PM
Integrity_On_Wheels's Avatar
Default Questions about Performance Chips
I was considering on looking into getting a Performance Chip for a 98 Non-Vtec GS model...first of all where is a good place to get them and what kind...most of all are they even worth it?
Also, is anyone familiar with or have personal experience with the Venom 400 ECU upgrade/add-on module...just looking for some feedback and opinions.
Thanks in advance.
Old Mar 1, 2006 | 04:50 PM
CleanLikeJdm's Avatar
Hype-R Stalker
Default Re: Questions about Performance Chips (Integrity_On_Wheels)
I don't think they'd make enough of a difference to notice,
First off mostly, if it adds more fuel or w/e, it won't do much, since it's still a stock engine.
Old Mar 1, 2006 | 04:54 PM
ohsnapzafingcu's Avatar
I serve phở for my babies
Default Re: Questions about Performance Chips (FlatBlackTeg)
and if you rev past 7 grand on your stock LS motor, your most likely gonna float a valve, and it's bad for your crank. and your cylinder walls will start flexiing.
unless you intend to take a speed govern off and screw with ur air/fual ratios and keep your stock limiter
honda knows best
Old Mar 1, 2006 | 06:38 PM
rkrone's Avatar
chip as in tuned ECU? that would be worth it, heres and idea, get the basic upgrades, cold air intake, IM, ...ect... then get some larger injectors, and fuel pressure regulator, at this point you will need to get a chipped ecu, and you will notice an actual difference
Old Mar 1, 2006 | 06:59 PM
InLimbo87's Avatar
Default Re: Questions about Performance Chips (rkrone)
yup.. preprogrammed chips = big waste of money, get a real tune or none at all
elliascool
May 4, 2011 04:54 PM
sparcocivic
Aug 9, 2006 01:47 PM
superbeastcrx
Sep 17, 2005 07:20 AM
Rod.
Oct 10, 2003 03:11 PM
Watkinsm3
Jul 29, 2002 08:57 AM
