question regarding alignment and camber
Old Feb 28, 2006 | 07:59 PM
.brian.'s Avatar
Default question regarding alignment and camber
quick question just to clarify something...
my car is lowered. i have front camber of about -2.0
i need an alignment. my steering wheel is facing to the right a little when i am going straight.
i do not have a camber kit. i do not plan on buying one in the near future.
my question is this.
can i still get an alignment (toe,caster) and also get my steering wheel on center without having the camber kit? obviously they cannot adjust the camber without it, but i don't care, i am more worried about the toe and the steering wheel.
thanks in advance.
Old Feb 28, 2006 | 08:01 PM
xteg95's Avatar
Default Re: question regarding alignment and camber (.brian.)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .brian. &raquo;</TD></TR><TR><TD CLASS="quote">quick question just to clarify something...
thanks in advance.</TD></TR></TABLE>
You can get your steering straightened but your toe will still be off a little.
Old Feb 28, 2006 | 08:03 PM
.brian.'s Avatar
Default Re: question regarding alignment and camber (xteg95)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xteg95 &raquo;</TD></TR><TR><TD CLASS="quote">
You can get your steering straightened but your toe will still be off a little. </TD></TR></TABLE>well my toe apparently is not too bad (about -.02)
stupid question....can i go to a shop and just tell them i want my steering wheel straightend?
thanks for the fast reply
Old Feb 28, 2006 | 08:05 PM
xteg95's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .brian. &raquo;</TD></TR><TR><TD CLASS="quote">well my toe apparently is not too bad (about -.02)
thanks for the fast reply</TD></TR></TABLE>
haha ... ya just tell them you want an alignment, it'll take care of your steering, your tires will still continue to wear unevenly though.
Old Feb 28, 2006 | 08:07 PM
.brian.'s Avatar
yea, i am more worried about toe wear than camber (from what i understand, toe wear is worse than camber?)
but just to get my steering straightend, i'm going to have to pay the full price for the alignment you think?
Old Feb 28, 2006 | 08:12 PM
xteg95's Avatar
yes sir.
yeah toe is worse, but they can get it straigened close to spec depending on how low your car is. toe is when your looking at the car from above and your tires are like this: / \ camber is when you look at that from behind your car. so caster and toe should decent enough after an alignment.
Old Feb 28, 2006 | 08:15 PM
teg racer 877's Avatar
get a full 4 wheel alignment, your steering wheel is turned cuz your toe is off a little, when the toe is corrected the wheel will be strait, dont worry about 2 deg camber, some guys run 2.7+ on purpose, toe is what causes tire wear, camber has some affect on wear but not much.
Old Mar 1, 2006 | 06:22 AM
.brian.'s Avatar
Default Re: question regarding alignment and camber (teg racer 877)
ok, thanks guys. i just wanted to check to make sure i took my car up to the shop and wasted my money. thanks
k_lude
Suspension & Brakes
Jan 17, 2011 12:47 PM
ShinotakuX
Oct 23, 2007 10:59 AM
gsr dood
Dec 28, 2005 11:16 AM
jdmfrontin
Aug 5, 2004 05:52 PM
N1Spec
Sep 5, 2001 07:10 PM
