suspension bump stops
Old Feb 26, 2006 | 04:06 PM
DAcraze's Avatar
Default suspension bump stops
what kind of bump stops did u guys use with ur new suspension setups? when took out my oem shocks their were nothing left of the oem bump stops.
Old Feb 26, 2006 | 06:24 PM
Sam92Teg's Avatar
Default Re: suspension bump stops (DAcraze)
I used my originals cut in half, so if you have your rear bumpstops, cut those in half and use one half on front and one half on the rear. I would make sure to have at least an inch worth of bushing as a bumpstop. Guess you could buy two OEM bumpstops and cut them also, or ES might have some for you.
Old Feb 27, 2006 | 06:58 AM
DAcraze's Avatar
Default Re: suspension bump stops (Sam92Teg)
when u did ur suspension were ur rear bumpstops just as worn as the front or are they usually fine?
Old Feb 27, 2006 | 01:10 PM
Sam92Teg's Avatar
All my original bumpstops were fine, and that was with over 240K miles at the time.
Old Feb 27, 2006 | 02:43 PM
TunerN00b's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DAcraze &raquo;</TD></TR><TR><TD CLASS="quote">what kind of bump stops did u guys use with ur new suspension setups? when took out my oem shocks their were nothing left of the oem bump stops. </TD></TR></TABLE>
I'm using the GC bumpstops that come with the upper mounts, and stock rear bumpstops, which I need to cut down or something.
GC sells bumpstops, by themselves. Check their site.
http://www.ground-control-stor...II=10
I'm thinking of buying some, instead of cutting my rears, just to keep the OEM ones intact, and a soft progressive one might be the best solution for me as I'm certianly low enough to make contact during street driving. And the 10-14mm ones should fit fine over either a stock shaft, or a Koni.
If you want my oem front stops, pm me, and we'll discuss shipping.
TOO MUCH TORQUE
Suspension & Brakes
Dec 2, 2013 12:51 PM
luis_88
Suspension & Brakes
Jul 17, 2013 03:48 PM
megatonhammer
Jul 10, 2013 10:26 AM
imadigitalgod
Jul 23, 2011 09:05 AM
*Boostwerks*
Suspension & Brakes
14
Jul 10, 2005 08:37 PM
