shifting problem. help!
Old Mar 5, 2006 | 02:39 AM
xintegr's Avatar
Default shifting problem. help!
something is wrong with my shifting. sometiems* when i leave it in first and let go of the clutch a little bit the car starts to shake, and its not because i let go of clutch tooo much, i usually do this but the car never shook this way before. and also all my gears are hard to put in sometimes. like when putting into 5th it feels like something is grinding. and when i wanna down shift to 4th or 3rd its very hard to put in, i have to shove it in. so im thinking its either low on tranny fluid, clutch is bad, syncro(sp) is bad, or my tranny is messed up. my car is at 96k and i bought it at 80k and not sure if its a new clutch or not. wut do u guys think is wrong?
Old Mar 26, 2006 | 11:44 AM
xintegr's Avatar
Default Re: shifting problem. help! (xintegr)
bump^
Old Mar 26, 2006 | 01:39 PM
96lsintegra's Avatar
da same happens to me, what would it be?
Old Mar 26, 2006 | 03:00 PM
Chewie's Avatar
Default Re: (96lsintegra)
Did you ask the previous owner if he/she changed the clutch. You said tranny fluid, so check it.
Old Mar 26, 2006 | 03:59 PM
JThrasher79's Avatar
Default Re: (Chewie)
mines the same, im pretty sure my clutch isnt engaging all the way so im changing my clutch fluid today. you might just have air in your lines also, does you pedal feel more "spongy" than before??
Old Mar 27, 2006 | 04:17 PM
xintegr's Avatar
bump^
Old Mar 27, 2006 | 07:31 PM
stumpyf4's Avatar
Sounds like the clutch is not fully disengaging. Check the fluid level in the clutch master cylinder. If low check for leaks at the clutch master and slave. My bet is that the clutch master is leaking, look under the dash, follow your clutch pedal up to the push rod that goes through the firewall.
https://honda-tech.com/zerothread?id=1516644
Old Mar 27, 2006 | 07:37 PM
CleanLikeJdm's Avatar
Hype-R Stalker
So this started All of a sudden, and not gradually?
kneeslide
Transmission & Drivetrain
Feb 22, 2010 11:51 AM
molezy7
Sep 4, 2008 05:57 PM
jack1
Nov 15, 2005 06:46 PM
RSVTECDC4
Oct 29, 2004 07:37 AM
monsterb18b
Nov 20, 2003 09:45 AM
