Compression Test #'s
Old Mar 2, 2006 | 07:18 PM
xvietxkhmerxboix's Avatar
Default Compression Test #'s
I did a compression test on my jdm 95 gsr motor and the numbers came out like this 220/230/220/215. Do these numbers look right if not what could be the problem? Motor has about 30,000-40,000 miles on it.
Old Mar 2, 2006 | 07:23 PM
Micha's Avatar
FAILWGN
Default Re: Compression Test #'s (xvietxkhmerxboix)
ummmm. They look decent. Looks like cylinder 2 is a little higher then the rest. But its okay. How does it run?
Old Mar 2, 2006 | 07:33 PM
Default Re: Compression Test #'s (Blu99teg)
it runs okay but when I take it out of gear and start to stop the idle drops really low and once in awhile it'll kill the car but I'll start right back up again. Is there away for me to make my compression read out a little better then wat I'm seeing now?
Old Mar 2, 2006 | 09:38 PM
bump for an answer
Old Mar 3, 2006 | 04:37 AM
bump2
Old Mar 3, 2006 | 04:44 AM
b16a2-t *turbocoupe*'s Avatar
was that a wet compression test or dry?? wet should give you a better reading and if it does that means ur rings arent the greatest ..
a wet compression test is when you put a teaspoon (about 15ml)of oil into each cylinder before testing it ... hope this helps..
Old Mar 3, 2006 | 04:46 AM
Default Re: Compression Test #'s (TURBOminimeCRX)
it was a dry test, and if it is my rings how much does it cost to replace?
Old Mar 3, 2006 | 05:34 AM
Sam92Teg's Avatar
Dude, your numbers are fine and your idle issue is something else. Try a valve adjustment and clean your IACV.
Old Mar 3, 2006 | 06:39 AM
tegG2's Avatar
Default Re: Compression Test #'s (Sam92Teg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sam92Teg &raquo;</TD></TR><TR><TD CLASS="quote">Dude, your numbers are fine and your idle issue is something else. Try a valve adjustment and clean your IACV.</TD></TR></TABLE>
Yea man dont sweat a biscuit. Your compression is fine.
Old Mar 3, 2006 | 03:05 PM
yee SERIOUS's Avatar
your compression looks good. it's only off by 5-10. not something to be really concerned about. if your car is sometimes dropping the idle too low and killin the car, try checking your timing and maybe change out your spark plugs or spark plug wires.
vtechjunkie
Apr 20, 2010 05:52 AM
dreamreaperx
Dec 20, 2006 02:01 PM
quaker
Jan 5, 2005 05:33 AM
gsr~hatch
Apr 17, 2003 03:19 PM
