How long of a test pipe?
Old Mar 2, 2006 | 10:48 AM
volcom40street's Avatar
Default How long of a test pipe?
I have a 98 teg with a RSR header for a 94 GSR. I know this header on a My teg with a b18b engine is shorter then the stock. there is going to be a gap between the header and cat. still going to use the stock b-pipe for now. Going 2.5 b-pipe in a couple months, so I know I will be bottle necking it for awhile.
I need to know if 17' omni test pipe is long enough to connect my RSR header(2" collector) to the front of the b-pipe?
Deos anyone have any experience on using a shorter header on a nonvtec motor and what test pipe they used. Or did you have to costom make it?
Old Mar 2, 2006 | 09:31 PM
Default Re: How long of a test pipe? (volcom40street)
anyone?
Old Mar 6, 2006 | 11:40 AM
up
Old Mar 6, 2006 | 11:58 AM
Danza's Avatar
I thought the omni testpipe was adjustable or something?
So this header is the same length as 94-99 gsr's, maybe you could find the cat that fits these cars.
Old Mar 6, 2006 | 05:34 PM
Default Re: How long of a test pipe? (Danza)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Danza &raquo;</TD></TR><TR><TD CLASS="quote">I thought the omni testpipe was adjustable or something?
So this header is the same length as 94-99 gsr's, maybe you could find the cat that fits these cars.</TD></TR></TABLE>
Let me reiterate a little. THe RSR header I have is for a b18c gsr, I have a b18b GS.
By me putting the RSR(header) on a b18b engine the header does not meet up with the cat, it doesn't extend to it, *too short*. I need to know by how much?? I can measure this, but I really don't want to go and take the stocker off and put the RSR on if someone can tell me here. I would appreciated it if someone has some knowledge or experience on this???
Does anyone know how much shorter a GSR HEADER IS THAN A LS HEADER on a B18b integra?????
I need to know if the omni 17 inch test pipe will stretch to fit the b-pipe with the RSR header???
Old Mar 6, 2006 | 05:49 PM
Danza's Avatar
Tell me how long your stock cat is. My cat for b18b's and 00-01 gsr's is 12.5" if I remember correctly with a jdm exhaust.
Let me reiterate, don't be a jackass and accept whatever help you can get.
-Ian
Modified by Danza at 10:07 PM 3/6/2006
Old Mar 6, 2006 | 06:06 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Danza &raquo;</TD></TR><TR><TD CLASS="quote">The header will fit a 94-99 gsr. The only difference is the header/a-pipe, so if you can buy whatever omni recommends for the 94-99 gsr, it will fit.
-Ian</TD></TR></TABLE>
Where in the HELL did that comment come from ?????? *Looks around puzzled*
Gotta love honda-tech.
Old Mar 6, 2006 | 06:11 PM
Danza's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by volcom40street &raquo;</TD></TR><TR><TD CLASS="quote">
Gotta love honda-tech. </TD></TR></TABLE>
The difference in header length is ~2".
The difference in cat length is ~2.5".
If you adopt an aggressive tone with me when I'm trying to help, you're getting in return.
There's your answer, have a nice day.
Modified by Danza at 10:23 PM 3/6/2006
Old Mar 6, 2006 | 06:14 PM
Danza's Avatar
PS the total difference in exhausts is about 4.5" longer for your car when compared to 94-99 gsrs.
So you'd need to add about 4.5" of pipe in your exhaust for it to work.
stock cat + 4.5" = the length you need
Old Mar 7, 2006 | 09:52 PM
96dc2's Avatar
You don't need to put it on to find out the difference in length. Improvise. Use a reference point such as the support bracket and measure to the collector.
Old Mar 8, 2006 | 12:16 AM
justmotor13's Avatar
For you i would suggest a 16 and 3/8th's inch length test pipe, worked good for my friends ride...
Slow_import
Nov 17, 2008 08:35 AM
DC2_2
Nov 25, 2006 09:36 PM
SleepnCiViC
Nov 24, 2005 12:36 PM
SleepnCiViC
Nov 10, 2005 08:19 AM
