Brake work problem/question...! HELP!
Old Mar 3, 2006 | 09:41 AM
b16a2EBP's Avatar
Default Brake work problem/question...! HELP!
Hello everyone,
i've been hearing grinding from my driver side brakes. i take a look at the rotors and it has deep gash lines that appear to be from the brake pad. what is it that i have to replace??? thanks!
Old Mar 3, 2006 | 10:14 AM
DA jeshy's Avatar
Default Re: Brake work problem/question...! HELP! (b16a2EBP)
you should take it in.
Your brake pads are down to the metal
Metal on metal = gashes on the rotor.
Your going to need new brake pads and rotors.
Old Mar 3, 2006 | 10:31 AM
LL2009's Avatar
Default Re: Brake work problem/question...! HELP! (DA jeshy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DA jeshy &raquo;</TD></TR><TR><TD CLASS="quote">
Your going to need new brake pads and rotors.</TD></TR></TABLE>
what he said
Old Mar 3, 2006 | 01:10 PM
b16a2EBP's Avatar
Cant i do it myself? how much will it be to replace rotor and pad? cant i just replace the pad and resurface the rotor? Thanks.
Old Mar 3, 2006 | 01:58 PM
dropped like its hot's Avatar
sure u can do it urself, about 60 bucks for pads and rotors at autozone
heres a run through
http://www.team-integra.net/se...D=373
Old Mar 3, 2006 | 05:58 PM
Sam92Teg's Avatar
Default Re: Brake work problem/question...! HELP! (dropped like its hot)
If your lucky, it could just be the wear indicator on the pad scraping the rotor, no harm done, just replace the pads.
Old Mar 3, 2006 | 07:09 PM
DA jeshy's Avatar
Default Re: Brake work problem/question...! HELP! (Sam92Teg)
Run your fingernail down the rotor… not up down. if your fingernail gets stuck then your need new rotors.
eg4life1202
Oct 29, 2006 10:09 AM
crx00
Apr 4, 2006 08:38 PM
Understeer
Suspension & Brakes
10
Mar 21, 2006 07:08 PM
seer_claw
Feb 24, 2004 08:13 PM
acuraLSSE95
Jul 28, 2003 06:39 AM
