b18c1 HELP!!!!
Old Mar 3, 2006 | 04:39 PM
JDMxNguyeN's Avatar
Default b18c1 HELP!!!!
how dose this sound, i have a gsr i want to put in b16 head, ctr cams, i/h/e, p30 pistons, ls rods (would they fit?) and how would this set up run?? its a daily driver
thx for your help (noobie)
Old Mar 3, 2006 | 04:50 PM
JDMxNguyeN's Avatar
Default Re: b18c1 HELP!!!! (JDMxNguyeN)
or should i stick with the gsr head???
Old Mar 3, 2006 | 04:52 PM
angelSIR-G's Avatar
why not stay with your gsr head, is it damaged???
your better off with it and you don't have to spend money on a new head
Old Mar 3, 2006 | 05:55 PM
da6jdmteg's Avatar
Default Re: b18c1 HELP!!!! (angelSIR-G)
the b16 head is a better flowing head than the gsr. the gsr's compression is only higher by.02. supposedly the ls rods and the gsr rods are different lengths. gsr are longer. there really aint to much different in the p30 and the p72 pistons. i would just order a aftermarket intake manifold for the gsr head. add the ctr cams. ive been building these things for a while. you dont have to take my advice. just trying to help.
Old Mar 3, 2006 | 05:58 PM
Lauj87's Avatar
i belive your going to need a LS crank if you want to use the Rods too...your compression should shot a good point with a b16 head as well...but it's a pretty good setup one of my friends has that...makes 180 at the wheels.
Old Mar 4, 2006 | 07:59 AM
JDMxNguyeN's Avatar
Default Re: (Lauj87)
waht if i keep my gsr head and do every thing else? like... ls crank and rods, p30 piston, i/h/e, and ctr cams? would this fit with the gsr head?
Old Mar 4, 2006 | 08:09 AM
JDMxNguyeN's Avatar
Default Re: (JDMxNguyeN)
should i jsut keep the gsr head and port and polish it and get an intake manifold? skunk 2? or is there another route to reliable hp? thx for the help
Old Mar 4, 2006 | 08:17 AM
SlamminS85's Avatar
it should fit with the gsr head, its not like the hed is goign to shorten the combustion chambers, the ls crank and the ls rods will give you a longer stroke, but it wont stroke above the chambers... it would however if you used LS rods and the GSR crank... vice versa would give you a very low compression engine
phelpsj2
Mar 17, 2010 02:09 PM
SEXY TIME!
11
Mar 22, 2006 08:44 AM
raider099
Apr 11, 2005 03:16 AM
Chonger1
Jan 28, 2004 12:32 PM
Mark
Oct 9, 2003 01:09 PM
