Check Engine
Old Mar 2, 2006 | 04:16 PM
AMG's Avatar
AMG
Default Check Engine
Quick Question:
Loosing alot of power across the board (*** dyno) and wondering why?
Question: (Brain Fart...Cant Remember) When checking the engine light the key must be 3/4 turn (right before actual ignition) right? If so then Im doing it correctly and ending up with the light staying on and not blinking. Just trying to remember if this is the ecu saying no problems to report.
Thanks
Old Mar 2, 2006 | 04:37 PM
AMG's Avatar
AMG
Default Re: Check Engine (_HondAddicT_)
No picture I know sorry.
Come on guys
Old Mar 2, 2006 | 04:40 PM
Micha's Avatar
FAILWGN
https://honda-tech.com/zerothread?id=1171263
Top of the civic page. Hope this helps.
Old Mar 2, 2006 | 04:42 PM
fmrprojects's Avatar
key should be in the key on, engine off position. if you have the light on the ecu goes into limp mode and vtec will not engage as it should
Old Mar 2, 2006 | 04:50 PM
AMG's Avatar
AMG
Default Re: Check Engine (Blu99teg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Blu99teg &raquo;</TD></TR><TR><TD CLASS="quote"> https://honda-tech.com/zerothread?id=1171263
Top of the civic page. Hope this helps. </TD></TR></TABLE>
Appreciate that man, but I know the codes.
My question is a little more simple then that:
If the light is just on does that mean its reading that then ecu is there. If it were to come on and then go off after a few seconds followed by a fast blink then I would know its throwing a code. Just cant rememeber what it means when it just stays on? Limp mode like Blu99teg said?
kuks24
Jun 3, 2008 05:33 PM
91b16acrx
Apr 20, 2008 09:20 AM
sublimenerd
Oct 19, 2006 09:11 PM
mahin
Honda S2000
Jan 12, 2005 10:55 AM
J MaCk gSR
May 21, 2004 05:26 AM
