battery relocation problem
Old Mar 1, 2006 | 06:09 PM
iheartmyej8's Avatar
Default battery relocation problem
i recently relocated my battery to the trunk of my da. when i did it the first time it wouldnt start but i could push start it. so i put a new starter and battery thinking that was the problem. but it wasnt. so i put everything back in the factory possition, then everything worked. so i figured it out that it was a ground problem. i had a ground from battery to chasis then from chasis to tranny bracket. that didnt create conduct enough. so i ran a 4 gauge ground wire from battery to front tranny bracket. i am running 0 gauge for power and 4 gauge ground. now the car runs, but then my alternator blew up after a week of running. was it a bad alternator or a screw up w/ the relocation? thanks for any helpful comments
Old Mar 1, 2006 | 06:24 PM
DC2 Mang's Avatar
Default Re: battery relocation problem (iheartmyeg)
i would try a new alternator and it if blows again then you are giving it too much power
when my friend and i relocated his we ran the wire from the trunk up to the starter and then directly placed the wire from the fuse box on the starter as well and it is running great
Old Mar 1, 2006 | 08:20 PM
CaseBone's Avatar
Default Re: battery relocation problem (JDMdc2lsVtec)
Yeah i recently relocated my battery also and my isnt doin anything at all!
Old Mar 2, 2006 | 03:48 AM
Default Re: battery relocation problem (X92B18C1TegX)
i do have a wire from the starter to the fuse box. im goin to try a new alternator tomorrow and see if that is the problem.
Old Mar 2, 2006 | 07:12 PM
i just got a new alternator today i am goin to install it 2morrow. i will let u know how everything works out.
Old Mar 2, 2006 | 08:26 PM
LMGSD760's Avatar
it could be the ground cabe on the alternator, my friend had a similar problem so, if and when you replace the alternator and it goes out again it could be that ground cable.
Old Mar 2, 2006 | 08:48 PM
integra3586's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iheartmyeg &raquo;</TD></TR><TR><TD CLASS="quote">i just got a new alternator today i am goin to install it 2morrow. i will let u know how everything works out.</TD></TR></TABLE>
make sure the connections from the battery to the alt are good or you gonna blow up the alternater again. your battery acts like a stabilized for the alternator. your car may run with just an alternator but will mess the alternator up.
why are you relocating your battery anyways?
Old Mar 2, 2006 | 09:10 PM
DC2 Mang's Avatar
Default Re: battery relocation problem (B18B-SC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18B-SC &raquo;</TD></TR><TR><TD CLASS="quote">
the battery takes up a huge ammount of space in the DA engine bay, it looks much better without it, and give you room for ignition parts, etc...
Old Mar 2, 2006 | 09:40 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMdc2lsVtec &raquo;</TD></TR><TR><TD CLASS="quote">
the battery takes up a huge ammount of space in the DA engine bay, it looks much better without it, and give you room for ignition parts, etc...</TD></TR></TABLE>
oh ok i was just wondering. i guess im just spoiled with my battery all tucked in a corner
Old Mar 4, 2006 | 03:12 PM
well i put it in. damn it sux but now everything is running good. if it blows up again how long do you think it will take to do so? and also could a too tight of a belt cause the alternator to blow? b/c i just put a new belt on like a month ago and it was tight as hell (like took 2 of us to get on), now the new one went right on w/ no real hard force. and the engine bay LOOKs sooo much better w/out the battery being all up in the way!!
Old Mar 4, 2006 | 03:20 PM
MyTeg8U's Avatar
[your car may run with just an alternator but will mess the alternator up.]
I beg to differ, I have ran my car without a battery, I did not have any problems with the altenator. About the wire being loose on the connection, I don't think it will do any damage, It will most likely arc from a poor connection. A little sand paper to roughen the surface up will help to get a better connection.
Correct me if I am wrong.
Ntraikoff
19
Oct 23, 2014 05:02 PM
wicked_b16eg
Jan 6, 2008 11:13 AM
crxh22project
Mar 14, 2005 04:52 PM
sky88
Jul 17, 2004 11:30 AM
KooK
Jul 21, 2003 02:49 PM
