redline??
Old Mar 7, 2006 | 09:33 AM
djstain's Avatar
Default redline??
yo in a stock b18c (p72 ecu isnt the redline suppose to be 8200rpm??? in my car i am geting my redline @ around 7300rpm any1 kno wat could cauz dat??? does dat have to do with distributor timing?
Old Mar 7, 2006 | 10:47 AM
98IntegraLSNonVtec's Avatar
Default Re: redline?? (djstain)
hmmm...deja vu...I could have swore I've seen this post before.
Old Mar 7, 2006 | 12:03 PM
SlammedDC2's Avatar
Semper Fidelis
Default Re: redline?? (98IntegraLSNonVtec)
I have a b18C1, and when I had my P72 in there I was redlining at 8500. Now I have a P30 with S100 and I redline at 9000. But I dont know why you are redlning low. Bump for some help.
Old Mar 7, 2006 | 01:13 PM
DC2 Mang's Avatar
sounds like you have a timing problem in which the ecu is not letting the motor rev past 7300 to keep you from damaging the motor
unless you have an ls ecu in your car which has a redline of around 7300 as well
Old Mar 7, 2006 | 01:58 PM
djstain's Avatar
Default Re: redline?? (JDMdc2lsVtec)
How can i fix it, i am sure its a p72 ecu, i feel it has something to do with the timing, how can i kno for sure?
Old Mar 7, 2006 | 02:26 PM
DC2 Mang's Avatar
drive it to a lube shop and have them set the timing at 16 degrees
Old Mar 7, 2006 | 02:33 PM
NaIsGay's Avatar
your tach could be off as well.. if its an ls ecu it wont hit vtec
my civic did that.. i thought it was redlining at 6000 but the tach was off
Old Mar 7, 2006 | 02:34 PM
LoseRPunKx182's Avatar
Default Re: (CustomX)
check ur crank timing
Old Mar 7, 2006 | 02:37 PM
four1one
Guest
Posts: n/a
Default Re: (LoseRPunKx182)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by djstain &raquo;</TD></TR><TR><TD CLASS="quote">yo in a stock b18c (p72 ecu isnt the redline suppose to be 8200rpm??? in my car i am geting my redline @ around 7300rpm any1 kno wat could cauz dat??? does dat have to do with distributor timing?</TD></TR></TABLE>
yur ecuz musta gun tu shitz 0r sumtin y0
Old Mar 7, 2006 | 02:40 PM
djstain's Avatar
when u say timing u mean distributor timing??
Old Mar 7, 2006 | 04:01 PM
DC2 Mang's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by djstain &raquo;</TD></TR><TR><TD CLASS="quote">when u say timing u mean distributor timing??</TD></TR></TABLE>
yes, and the crank timing because you may have jumped a tooth on the timing belt
Old Mar 7, 2006 | 04:07 PM
Dogginator's Avatar
Daisy... Daisy...
Is it hitting the rev limiter at that RPM? (The rev limiter caused the engine to cut in and out.) Or will it just not rev beyond 7200RPM due to lack of power?
Old Mar 7, 2006 | 04:30 PM
four1one
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMdc2lsVtec &raquo;</TD></TR><TR><TD CLASS="quote">
yes, and the crank timing because you may have jumped a tooth on the timing belt</TD></TR></TABLE>
I dont think his car would start let alone run if it skiped a tooth and if it did run it wouldnt get that high up in the rpm range.
Old Mar 7, 2006 | 04:42 PM
DC2 Mang's Avatar
Default Re: redline?? (four1one)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by four1one &raquo;</TD></TR><TR><TD CLASS="quote">
I dont think his car would start let alone run if it skiped a tooth and if it did run it wouldnt get that high up in the rpm range.</TD></TR></TABLE>
cars start and run wehn they have jumped a tooth, my friend has had it happen more than once
Old Mar 7, 2006 | 04:44 PM
four1one
Guest
Posts: n/a
cars start and run wehn they have jumped a tooth, my friend has had it happen more than once</TD></TR></TABLE>
Depending on the car some could, but i doubt your friend skiped a tooth then reved to 7300 tho did he?
Old Mar 7, 2006 | 05:04 PM
DC2 Mang's Avatar
Depending on the car some could, but i doubt your friend skiped a tooth then reved to 7300 tho did he?</TD></TR></TABLE>
no because he was driving a single cam that couldnt rev that high
im just giving possibilities of what could be wrong, im saying to check timing because it could be off due to one thing or another
danmej1
20
Jan 2, 2010 05:55 PM
99lspwr
Nov 29, 2005 03:23 PM
wilsel
Mar 23, 2005 05:37 PM
01PYTypeR#1140
Jul 17, 2001 06:33 PM
