Need help with headlight!!!!!!
Old Mar 7, 2006 | 07:12 AM
vietintegboi's Avatar
Default Need help with headlight!!!!!!
I'm just got into the car mod thing.......so i'm not sure how to do stuff....I wanted to change my factory headlight bulb on the integra to a hylogen one (the white one)......i'm not sure how to take it apart.........anybody have any idea how to install it.....
Old Mar 7, 2006 | 07:17 AM
Danza's Avatar
Default Re: Need help with headlight!!!!!! (vietintegboi)
1. It's called a halogen bulb, as in the family of gases.
2. You have them in your car already, but I'm going to assume you mean the
whiter variety (osram silverstars etc.).
3. You'll see a connector on the back of the headlight with a rubber boot around it. You need to remove this connector by twisting it and then put in the new bulb.
Careful not to crack the bulb/headlight when you twist.
Old Mar 7, 2006 | 07:55 AM
NesaiTuner's Avatar
Default Re: Need help with headlight!!!!!! (Danza)
also when you change your bulb make sure not to touch the glass. The oils from your finger will cause a hot spot and cause the bulb to burn out. if by accident you do touch it. wipe it down with alchohol.
Old Mar 7, 2006 | 08:13 AM
Danza's Avatar
Default Re: Need help with headlight!!!!!! (NesaiTuner)
And you need 9006 bubls for the low beams
Old Mar 7, 2006 | 08:52 AM
Darkint3gra's Avatar
Don't put in blue bulbs....companies advertise that blue halogen bulbs will give you better light output and better vision...the truth is that they will do the exact oposite. go with some silverstars or PIAA headlight bulbs. they will give you the best night vision as far as a halogen bulb goes. if you are really looking to see well at night and have about 300$ to spend on lights...go for some HID's ( high intensity discharge) you can get an hid plug and play kit for around 300. from what i hear about them you won't regret it. 3 times the light output of a halogen bulb and they last ten times as long before burning out...
BrutalDawg
Oct 13, 2007 07:11 PM
sittingonROTAS
Nov 1, 2005 05:04 PM
mynond
Jan 31, 2004 09:29 PM
