abs light
the code...then your abs fuse, fluid, etc.
You can get the code the same way as you would to jump the ecu. Your ABS codes are stored as well.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iH8RICERZ »</TD></TR><TR><TD CLASS="quote">You can get the code the same way as you would to jump the ecu. Your ABS codes are stored as well.
And you could check what the codes mean here:
https://honda-tech.com/zerothread?id=978933
Ali
Ali
I'm curious if anyone has a actual answer. I have the same code/problem. I haven't had the time nor energy to hunt down what the problem is, so I just drive without abs :D
good luck
good luck
Looked into it a little for you. Everything in the factory manual points to replacing the accumulator because it's non-serviceable. Couldn't find a part number or a price for you though.
