Idle Problem
Old Mar 6, 2006 | 07:36 PM
nikkon's Avatar
Default Idle Problem
I just put a new motor in my dc2 and when I start it the idle sits at 2,000rpm after it warms up the idle will eventually drop to 800.If u let it sit for a while it will start idling up and down from about 800 to 1k rpm.I have already rlaced the IAC valve,TPS,MAP sensor,redone the FITV and replaced all vacum lines.Anyone know any other ways to fix the problem???
Modified by nikkon at 9:31 PM 3/6/2006
Old Mar 6, 2006 | 08:23 PM
no2unenolife's Avatar
have you tried messing with the idle screw yet
Old Mar 6, 2006 | 08:30 PM
nikkon's Avatar
Yes,Im not sure where the stock setting is but right now its almost all the way closed.
Old Mar 6, 2006 | 08:31 PM
iBrandon's Avatar
Default Re: (no2unenolife)
im running a 70mm bbk...i had idling issues...i found out that the gasket they gave me overlapped where the actual throttle turned..it was restricting its position to go back to idling state...so i trimmed that..so check ur gasket if its overlapping...
also like said...play with ur screw..mine tends to flucuate once in a while but goes back down after a few secs or so...but hell..ill live with it...
Old Mar 7, 2006 | 07:17 AM
nikkon's Avatar
Sill cant get it to idle right.
Old Mar 7, 2006 | 07:20 AM
Lan's Avatar
Lan
Default Re: (nikkon)
Have you done a valve adjustment?
Old Mar 7, 2006 | 08:31 AM
nikkon's Avatar
Havent had a valve job done yet.Also when I let the car idle it will run for like 10 sec then it seems like it stumbles and does it repeatedly.
Old Mar 7, 2006 | 08:33 AM
Lan's Avatar
Lan
Do the valve adjustment, see what happens. That might fix you right up
Old Mar 7, 2006 | 04:33 PM
nikkon's Avatar
Will get one done soon any other thoughts on the subject?
Old Mar 7, 2006 | 06:29 PM
go250mph's Avatar
Check that distributer out.
Old Mar 8, 2006 | 10:11 PM
nikkon's Avatar
Dizzy has a new cap,rotor,and coil.The bearing still spins like new.
Old Mar 8, 2006 | 10:19 PM
solareclipseauto's Avatar
try bleeding the coolant, might be air trapped in the line
Old Mar 10, 2006 | 09:44 PM
nikkon's Avatar
will try the coolant tomorrow
Old Aug 3, 2011 | 06:21 PM
go250mph's Avatar
Default Re: Idle Problem
I know this is an old thread...but was it one of the temp sensors?
ejvtec
Jan 26, 2011 07:33 AM
92egSnatch
Mar 22, 2008 08:55 PM
B16Hatchcx
Apr 26, 2003 11:40 AM
PSU-TEG
Mar 11, 2003 07:28 AM
