ls compression
Old Mar 7, 2006 | 04:49 PM
reallycooleg's Avatar
Default ls compression
i gotta 1995 ls motor
comp is
160 160 158 160
is that too low...car runs great and pulls hard..
Old Mar 7, 2006 | 04:50 PM
92integraVTECgsr's Avatar
Default Re: ls compression (reallycooleg)
bump.. would also like to know.
Old Mar 7, 2006 | 04:59 PM
Integra Integra's Avatar
Default Re: ls compression (92integraVTECgsr)
My 1999 Integra LS w/ 77k miles had 180 PSI all across the board are you sure you pressed your throttle all the way down? If it wasn't it would give you a lower reading
veilsides2000's Avatar
where in farifax are you located man?? i used to live there too.
Old Mar 7, 2006 | 05:02 PM
It's*BOLO!!'s Avatar
Guess whos bizzack
Default Re: ls compression (veilsides2000)
https://honda-tech.com/zerothread?id=1481352
Old Mar 7, 2006 | 05:04 PM
Guess whos bizzack
how many miles are on this?
Old Mar 7, 2006 | 05:08 PM
aeon's Avatar
that does seem a little low..
Old Mar 7, 2006 | 05:12 PM
95integraSE's Avatar
mine was 202, 202, 202... except the #1 was 185
Old Mar 7, 2006 | 05:23 PM
aeon's Avatar
yeah i did my compression test a couple days ago and got 192 - 190 - 182 - 192
Old Mar 8, 2006 | 03:53 PM
maybe i perfromed the test wrong ...all i did was put the compression tester in the spark plug holes and crank it over till the needlde stopped moving up....i guess thats completley wrong....and i live close to fairfax
Old Mar 8, 2006 | 04:03 PM
integra racr04's Avatar
the LS compression is supposed to be 200 in all 4 clyinders....
Old Mar 8, 2006 | 04:12 PM
Default Re: ls compression (integra racr04)
Your supposed to keep the throttle open (gas pedal depressed all the way down) if you do not do that the results will be lower and give you a false reading
Old Mar 8, 2006 | 04:22 PM
Uncle Ben's's Avatar
Cogent Argument Enthusiast
Default Re: ls compression (Integra Integra)
i dont think it matters that much what the levels are, as long as theyre about the same in all cylinders. mine was 150 across the board a couple years ago, still running strong. according to Shopkey it should be higher than 135 with a maximum of 12% variation between cylinders. i did the three jumps of the needle method. most people on here use 10 rotations to find the number, maybe that makes a difference.
Old Mar 8, 2006 | 09:06 PM
ForceFed Motorsports's Avatar
Do you even PLEBE R8?
Default Re: (reallycooleg)
Pull all of the spark plugs, turn over five times, then record highest reading. You should check alldata for your compression specs.
That is ok though for the record, as long as your readings are all close to the same and your car runs fine any technician would tell you to leave it.
2ndgentegracer
Mar 7, 2006 04:29 PM
redDAinteg
May 25, 2005 04:31 PM
B18PoweredCivic
Nov 12, 2004 03:49 PM
ninja8oi
Apr 4, 2004 10:58 AM
