problem with AC blower
Old Jun 3, 2006 | 12:21 PM
mymeatb18
Default problem with AC blower
wuts going guys, i have a 90 DA and it was recently converted to r134a and its all good and fine but the lasts couple of days the blower fan just seems to not work sometimes. i would be using ac all fine and **** turn off the car then later get back in and the blower doesnt blow any air. i checked the lines when the ac is on and they get cold so i know the compressor is working but no air.
any feedback is greatly appreciated so thanks in advance
Old Jun 3, 2006 | 03:59 PM
Sam92Teg's Avatar
Default Re: problem with AC blower (mymeatb18")
Your blower motor is probably shot, for a temp fix, you can try to shoot some spray lubricant into the hole on the side where the hose goes into the bottom of the blower motor. Worked for me.
Old Jun 3, 2006 | 05:41 PM
mymeatb18
Default Re: problem with AC blower (Sam92Teg)
but its not like it started to work less and less it just does that out of no where like some wire might be loose or something
Old Jun 3, 2006 | 06:04 PM
93_teg_CT's Avatar
Mine's doing the same thing, But before that it worked excellent except 4, 4 didn't work at all and someone told me it was the blower motor resistor.
Old Jun 3, 2006 | 07:37 PM
mymeatb18
Default Re: problem with AC blower (93_teg_CT)
where is that located in the car and so is your blower fixed now, no problems?
Old Jun 3, 2006 | 07:46 PM
Sam92Teg's Avatar
The blower resister is located on the blower housing directly under the glove box, it is black and has wires connected to it. I think it is held on by 2 phylips screws.
You usually will lose speeds when it goes out.
Old Jun 3, 2006 | 08:29 PM
mymeatb18
well im not so sure thats it if you would be losing speeds. when it works it works perfectly fine all the speeds work and what not but right now the buttons are stuck, so its stuck on getting air from outside and sometimes it keeps switching between that and recirculate but im sure it nothing to do with my problem
Old Jun 4, 2006 | 06:03 AM
mymeatb18
well i went to go check if the blower was working today and it doesnt even work at all now. but if i switch from recirculate to outside air i can hear it switching so could it still be possibly the blower resistor or is my blower shot
Old Jun 4, 2006 | 06:31 AM
mr.beeks's Avatar
just clean it up and spray some lubricant so the motor will work again...
Old Jun 4, 2006 | 12:57 PM
mymeatb18
Default Re: problem with AC blower (mr.beeks)
yeah scratch that last thing i said i went and checked it later and it worked but now it aint. but i need to go to the junkyard anyways so i'll just get the resistor to see if that works and also lube tha bitch
Old Jun 10, 2006 | 03:11 PM
mymeatb18
alright i changed the resistor and still nothing so i guess that leaves the blower motor but before i change that i want to try lubing it up so where exactly is it that you lube it
E30LS1
Honda Civic (2001 - 2005)
Jul 9, 2014 09:40 AM
94eh2
Honda CR-V & Element
Jun 15, 2013 10:56 AM
MUGENVX9
Mar 7, 2013 06:20 PM
QuestMCoupe
May 17, 2012 10:39 AM
sk8phaze
May 14, 2003 04:04 PM
