need some help with a jumping idle needle...
Old Jun 4, 2006 | 11:32 AM
sickassride's Avatar
Default need some help with a jumping idle needle...
what can be wrong.. as i turn on the car..it stays at its normal idle speed..and then all of a sudden it takes a big jump up to 1 nearly 2 rpm.. whats can be wrong?
Old Jun 4, 2006 | 11:39 AM
Dogginator's Avatar
Daisy... Daisy...
Default Re: need some help with a jumping idle needle... (sickassride)
Your IACV (Idle Air Control Valve) is probably dirty.
Old Jun 4, 2006 | 11:41 AM
Default Re: need some help with a jumping idle needle... (Dogginator)
can we clean it ourselves or need to get a new replacement one?
Old Jun 4, 2006 | 12:13 PM
Dogginator's Avatar
Daisy... Daisy...
You can try to clean it one of several ways. The easiest is to remove the air intake and spray carburetor cleaner into the hole for the IACV while the engine is running. The hole is in the inlet for the throttle body before the butterfly. The car will most likely stall a few times since you are essentially flooding the engine. However, the carburetor cleaner is passing through your IACV. The other method involvs removing the IACV and cleaning it. It is much more involved.
Old Jun 4, 2006 | 12:14 PM
Lauj87's Avatar
does your car idle like this or just the needle jumping? if its just the needle then do a tune up but if your engine is idleing like that then clean your IACV or get a new one.
wildoutwhitegsr
Jun 27, 2024 04:43 PM
2low93
Feb 17, 2012 04:13 AM
b20beast83
Aug 7, 2008 04:57 PM
Froch
Jan 13, 2008 12:16 PM
4ghatch
Sep 28, 2005 02:59 AM
