ABS question.
Old Jun 3, 2006 | 06:42 PM
GREENMOB$TER's Avatar
Default ABS question.
My 94 Integra LS just started acting up with the ABS. The ABS light is always on now, and everytime I come to a stop, the brake makes a "click---click sound, and then it sounds like something slipping in the ABS motor. I'm confused as hell to what this is, and I dont want to take it to a shop if it's something minor. Can someone try to take a shot at what this problem might be?
Old Jun 3, 2006 | 07:55 PM
JasonST's Avatar
Default Re: ABS question. (GREENMOB$TER)
Bump. I would like to know the answer to this too. After my h22 swap my ABS light has been on forever, and I can get it to blink either to check codes.
Old Jun 3, 2006 | 08:25 PM
maxxb0y's Avatar
jumper out the Service Check Connector just to the right of the glove box. turn on the ignition without starting the engine. record the blink frequency of the abs light. This is the diagnostic code . There may be long and short flashes so take note of these. this makes up a code to find out the problem... If you cant find the code online Hit me up and I can help. I have the same problem. My problem came to be a 7-4 or a rear solenoid.
Old Jun 4, 2006 | 07:07 AM
JasonST's Avatar
Default Re: ABS question. (maxxb0y)
Thanks for the info, but as I was just saying, my ABS doesn't blink, I jumper it, and the CEL will blink if there is one, but the ABS light just goes out and doesn't blink at all, when I take the jumper out, it's constantly on, it just won't blink. Any ideas?
Old Jun 4, 2006 | 07:59 AM
Default Re: ABS question. (JasonST)
My ABS motor is making a click click noise, and the sounds like it's winding out. I'm stumped, I'll try the code thing though.
Old Jun 4, 2006 | 02:45 PM
maxxb0y's Avatar
ok, i only gave you part of the info... whn you first turn it on depress the pedal until the light goes off. then let it up. then when the light comes on again depress the pedal... This may clear the abs light . if it doesnt... start over and see if the light blinks again.... ill try to help more if i can ... later
Old Jun 4, 2006 | 03:18 PM
GranadaTeg's Avatar
How is the ABS fluid?
Old Jun 4, 2006 | 04:35 PM
Default Re: ABS question. (Slo Cord)
Where do you fill the abs fluid?? Sorry I don't know much about it.
Old Jun 4, 2006 | 05:05 PM
AllmansDB8*'s Avatar
If your'e installing the jumper wire correctly, and the ABS light is NOT flashing
then you may have an issue with the ABS module. Make sure you are following
the procedure correctly, and if you are then you may need to dig further.
Old Jun 4, 2006 | 07:02 PM
GranadaTeg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GREENMOB$TER &raquo;</TD></TR><TR><TD CLASS="quote">Where do you fill the abs fluid?? Sorry I don't know much about it.</TD></TR></TABLE>
mr_munro
Mar 14, 2012 11:53 AM
ChesterNL
Aug 1, 2011 11:35 PM
basmasta7
Mar 31, 2010 06:54 AM
DC206R
Oct 18, 2009 09:26 AM
joenoreason
Apr 28, 2007 08:56 PM
