Rattling
Old May 31, 2006 | 03:58 PM
prophetjinn's Avatar
Default Rattling
As the title says, i'm hearing a rattling noise, usually around RPM's over 3k and when i undershift sometimes. it's coming from the front passenger side, i'm thinking it's the caliper because one of the bolts that closes it is twisting so i cant take it off when im changing my pads, i have to slide it in, could it be the caliper? I've also been having a problem with the rotor on that side sliding against the pad, so i'm thinking it could be that too... could it be my tranny? or could it be the rotor/caliper?
Thanks always HT
edit: the rattling sounds kinda like something's overspinning and immediately stops when i let go of the gas
Old May 31, 2006 | 04:12 PM
BOOSTED RIVAL's Avatar
Default Re: Rattling (prophetjinn)
It could just be the heat shield for the down pipe.
Old May 31, 2006 | 04:14 PM
CleanLikeJdm's Avatar
Hype-R Stalker
doesn't sound brake/suspension related if it stops when let off the gas,
have you checked all of your exhaust?
Old May 31, 2006 | 04:36 PM
I dont even know what im looking for.. it all looks bolted on tight though..
Old May 31, 2006 | 04:39 PM
Hype-R Stalker
Default Re: (prophetjinn)
Don't just look though, jack up the car, and get your hands on it, shake each piece.
Then you'll have a much better idea if it's the exhaust or not,
also, if you're sitting still and rev the car, will it rattle, or is it only when you're moving?
Old May 31, 2006 | 04:40 PM
Nors's Avatar
Don't do what the above poster said right after driving or while car is on.
It needs to cool down.
Old May 31, 2006 | 04:46 PM
Hype-R Stalker
Default Re: (Nors)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Nors &raquo;</TD></TR><TR><TD CLASS="quote">Don't do what the above poster said right after driving or while car is on.
It needs to cool down.</TD></TR></TABLE>
Lol, I would hope he'd have enough sense to not do it while Hot.
Old May 31, 2006 | 04:59 PM
Default Re: (FlatBlackTeg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FlatBlackTeg &raquo;</TD></TR><TR><TD CLASS="quote">Don't just look though, jack up the car, and get your hands on it, shake each piece.
also, if you're sitting still and rev the car, will it rattle, or is it only when you're moving?</TD></TR></TABLE>
It's only when im going, which is why i think it's a brake problem @_@
Old May 31, 2006 | 05:45 PM
Fat Chick Magnet's Avatar
My cat rattled crazy around 3k-4k when i would let rev-match into a low gear in high rpm i would let it drop to 4k and it would start to rattle. I just recently installed my test pipe. Try checking your cat or your exhaust pipes.
Old May 31, 2006 | 06:01 PM
My cat seems ok, everything's bolted on tight..
Old May 31, 2006 | 06:41 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by prophetjinn &raquo;</TD></TR><TR><TD CLASS="quote">My cat seems ok, everything's bolted on tight..</TD></TR></TABLE>
it could be from inside the cat.
Old May 31, 2006 | 06:50 PM
Hype-R Stalker
Try jacking your front up and spinning the tires?
Old May 31, 2006 | 07:00 PM
92integraVTECgsr's Avatar
Default Re: (Nors)
jack the car up.. bang around with your hand and feel everything.. check all nuts and bolts.
i had this rattle for the past few days, turned out to be a bunch of rocks got up under the cover that covers the gas fill neck.
Old May 31, 2006 | 07:15 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FlatBlackTeg &raquo;</TD></TR><TR><TD CLASS="quote">Try jacking your front up and spinning the tires?</TD></TR></TABLE>
Good idea.. i just hope i dont hit my sister's Accord hahaha
Old May 31, 2006 | 07:19 PM
Hype-R Stalker
lmao, oh come on, it's an Accord
Just tell her some angry ex dented it if anything happens hahah.
Old May 31, 2006 | 07:22 PM
Well it's already broke down as it is, and i wasn't worried about her car, i mean i dont wanna ruin my bumper lmao
Old May 31, 2006 | 07:25 PM
Hype-R Stalker
lol, okay now that's much better reasoning
David12
11
Nov 9, 2009 12:40 PM
Fantastic420
Aug 25, 2009 04:27 PM
CivicWagonRUS
May 19, 2007 11:46 AM
Kyles ej1
12
Aug 30, 2004 07:09 PM
JDubya
May 23, 2004 07:45 AM
