Dash Change...Cluster Help
Old Jun 2, 2006 | 02:58 PM
BlackDC4's Avatar
Default Dash Change...Cluster Help
"i searched before you say it"ok i changed my tan dash to black,switched the harness from the old dash to new and when i installed everything back in the car, my cluster wouldnt light up nor the climate control.ok, found a plug under the dash i missed and plugged it in and its been fine since,.now for the real question.i did the same dash change to my girlfriends car and her cluster/climate control wont illuminate. looked for the plug to be the prob,(as it was mine) and as far as i can see, they are all in tact and plugged in....any ideas,....oh and the fuse is fine and tail lamps illuminate also.any hep i' really appreciate..really a dagram or w/e of the plugs behind the fuse box would help. its a 1997 GS Integra.Thanks
Old Jun 3, 2006 | 11:22 AM
BlackDC4's Avatar
Default Re: Dash Change...Cluster Help (BlackDC4)
Yea I'm Just Looking For Suggestions Or Something.Bump
Old Jun 3, 2006 | 11:25 AM
Integra9000's Avatar
maybe a bad wire. something crossing. make sure the wires arnt all old looking and beat to hell. ive had cross wires and that crap sucks. noone like to play with electronics, just the engine work for me. good luck man
Old Jun 6, 2006 | 01:17 PM
BlackDC4's Avatar
Default Re: Dash Change...Cluster Help (Integra9000)
thanks man, but u used the factory harness and no exposed wires so i dont think thats what i've run into...anyone else with an idea?
Old Jun 6, 2006 | 09:16 PM
SpydiR's Avatar
as I understand it you are using the original cluster, climate, etc., and swapping in a new dash and harness? if it worked before and it doesn't now, it's quite obviously a problem with the wiring. remember, you never know what stupid **** previous owners have done
Old Jun 7, 2006 | 02:04 AM
BlueIntegraBoy's Avatar
check your dimmer switch. if it goes bad or is unplugged, your dash lights won't work.
Old Jun 9, 2006 | 01:24 PM
BlackDC4's Avatar
Default Re: Dash Change...Cluster Help (BlueIntegraBoy)
blueintegraboy...if that fixeds it i will be greatly in debt to you man, its really worried me and i really dont remember pluging that back up....im excited now, haha, the wiring wouldnt make sense cause everything works...just no illumination....thanks guys....good stuff i'll let you know if that fixes it
darkd1gt
Jul 15, 2007 11:37 AM
tksavestheday
Feb 4, 2007 02:12 PM
JDM EJ1 95
Dec 13, 2004 04:13 PM
DeeJayStkyRice
Mar 2, 2004 09:01 PM
92B20GSR
Oct 16, 2003 06:10 PM
