Cold Starting Problem
Old May 22, 2013 | 11:08 AM
mikeybee95's Avatar
Default Cold Starting Problem
I have a 95 LS Integra with a stock b1 and 5 speed trans. Recently i have been noticing when i go to start my car in the morning (or after sitting for 4+ hours) I have to crank it about 20-30 seconds before it will start. I thought it was the fuel pressure regulator, i changed that and i still have the problem. I just put a new fuel pump and sending unit in and blew out the lines from the fuel filter to the pump. Also i put on a new fuel filter about 2000 miles ago. I recently within the past 1000 miles changed my plugs and wires. My distributor is only about 6000 miles old. I honestly have no idea what is causing this. Im not throwing a check engine code.
Old May 22, 2013 | 12:15 PM
fcm's Avatar
fcm
Old Fart
Default Re: Cold Starting Problem
Check ECT sensor, it supplies ECU/ECM with engine temp., if it indicates a warm engine even though it is cold, it will be hard starting when cold but not when warm. 94
Old May 22, 2013 | 06:06 PM
el crapitan's Avatar
when it finally does start cold, does it high idle like it should?
and yes, i agree, ect sensor. but if not that, i'm leaning towards fitv, if equipped
Old May 23, 2013 | 02:30 AM
mikeybee95's Avatar
Yeah when it starts it does idle high like it should, also no misfire or running rough when it starts. Isn't the ECT sensor on the cylinder head under the distributor?
Old May 23, 2013 | 06:08 AM
yes. it will be a 2 pin sensor under distr.
dperfect
Feb 22, 2014 10:05 PM
eXcelon969
Aug 18, 2011 09:39 AM
Maireeka
16
Aug 9, 2007 06:46 PM
Quetzolcotl
16
May 19, 2002 04:43 PM
