bad head gasket?
Old May 25, 2013 | 04:54 PM
accord94cd7's Avatar
Default bad head gasket?
i got a 95 ls and it over heats after driving for about 15 min. the fans do work, i replaced the stat and even tired with no stat seeming i live in fl and it would be open anyways but it still over heated. i had a coolant pressure test done and it held pressure. it seems that when it starts to get hot the coolant reservoir fills up and when the car cools down it goes back into the rad. just recently i put coolant got the air out took it out for a spin and when it started to over heat i brought it home the res was semi full i unscrewed the air bleeder valve thing and it just keep pouring steamy got air and a few squirts of coolant here and there. idk what else to try. if i fill up my rad and turn my car over with the rad cap off its kind comes out but not like a geyser. any ideas? is there a bad head gasket?
Old May 25, 2013 | 05:08 PM
B_Swapped93's Avatar
Default Re: bad head gasket?
is there white smoke coming from your exhaust milky like substance on your oil fil cap. have/can you do a leakdown test ?
Old May 25, 2013 | 05:22 PM
no white smoke and no milky substance on oil stick or cap. i have not had a leask down test but i think i will have one done tomorrow for sure. one of my friends said the head gasket could be bad and pressurizing my coolant system but idk what going on lol
Old May 26, 2013 | 09:04 PM
nicknack25's Avatar
Have you ever changed your water pump?
Old May 26, 2013 | 11:03 PM
SHspec's Avatar
Check the hoses from the radiator to the block, there might be a leak from old cracking rubber hose.
Old May 27, 2013 | 07:52 AM
S2BumpsticksGSR's Avatar
Seriously? A leaky hose will leak steam/coolant when the system is pressurized.
Old May 27, 2013 | 10:38 AM
skill178's Avatar
If u got no water in the exhaust or oil its probably not blown but might be, check your water pump
Old May 27, 2013 | 04:25 PM
teggy!'s Avatar
pop your rad cap and let car warm up....see if u see bubles coming out
Posted from Honda-tech.com App for Android
deerman2701
18
Sep 6, 2013 01:55 PM
MarkM01
Honda Civic (2001 - 2005)
Apr 10, 2011 04:21 AM
highrollers23
Sep 2, 2009 06:54 PM
Mr_Moos
Feb 13, 2006 05:59 PM
CiViC I2aCeI2
Jan 20, 2006 06:49 PM
