AC replacement
Old Jun 9, 2013 | 10:40 AM
Johnoolo's Avatar
Icon2 AC replacement
Can I replace my stock ac with a smaller ac unit and what car should I get replacement ac from?
Old Jun 9, 2013 | 02:35 PM
fcm's Avatar
fcm
Old Fart
Default Re: AC replacement
A/C unit???
What part, compressor, condenser, evaporator??? 94
Old Jun 9, 2013 | 03:12 PM
Johnoolo's Avatar
The compressor
Old Jun 10, 2013 | 05:43 AM
fcm's Avatar
fcm
Old Fart
You can use any compressor you want.
There are three (3) issues you will run into...
1- Mounting, compressor needs to be mounted securely with pulley squarely lined up with crank pulley, [compressor also has to have the correct pulley].
2- Manifold fittings, either you have to find a compressor with the same fittings, [suction/discharge] as the stock fittings or you have to modify the lines.
3- Capacity, like just about anything a smaller compressor will not have the capacity of the stock compressor so "cooling" will be effected, how much will depend on a number of things.
So the question is, why? 94
Old Jun 10, 2013 | 08:08 AM
Johnoolo's Avatar
My tensioner pulls broke and I'm trying to reduce engine drag
Old Jun 10, 2013 | 04:16 PM
fcm's Avatar
fcm
Old Fart
A smaller compressor will not help, the drag will be the same as head pressures, [A/C head pressure] will be about the same. 94
2old_honda
May 29, 2011 12:35 PM
nickelz34
10
Aug 31, 2009 07:55 PM
Davidss
Jul 16, 2009 05:51 AM
