Speedometer not working
Old Jun 19, 2013 | 09:27 AM
rak511's Avatar
Default Speedometer not working
My speedometer isn't working in my integra. Swapped clusters with my friend and its not the cluster. Swapped vss with one (not sure if it was good or not) didn't work, the wires were cut going to the vss but I matched up the colors still dosnt work. It has ls vtec with p28 ecu. My vtec wont work without the speedometer working. Any ideas?
Old Jun 19, 2013 | 09:31 AM
kyden's Avatar
Default Re: Speedometer not working
did you check the wires for continuity?
Old Jun 19, 2013 | 09:55 AM
B_Swapped93's Avatar
check for corrosion on(inside) the plugs on the vss and on the harness side.
Old Jun 19, 2013 | 11:09 AM
POPLERO's Avatar
how did u reconmect the cut wires? soldering is best..
Old Jun 19, 2013 | 11:15 AM
JuggerNaut-CTR's Avatar
^x2
Corrosion on pins inside plug is very common. Plug not fitting tight anymore is another. When it happened to me it was a little of both. More times than not its the plug.
Old Jun 20, 2013 | 09:10 PM
Johnoolo's Avatar
Check the fuses I had same problem it was the spedo fuse
Old Jun 21, 2013 | 09:06 PM
rak511's Avatar
Figured it out, was just vss, guess my friend handed me wrong one to put in when we switched it before... smh... thanks anyway guys
beat
Jun 7, 2010 01:33 PM
so simple
Jan 17, 2008 02:03 PM
Pnoyej6
21
Jan 18, 2007 01:13 PM
NobodysHero
Jun 3, 2005 01:09 PM
plusONE DC2
20
Aug 17, 2004 07:47 PM
