Weird brake problem
96 Acura Integra Stock
To make a long story short, car was acidentally driven with constant brake pedal slightly pressed. After a few miles on the freeway, steering wheel and car shook pretty bad. I'm assuming it was being heated up to max. Upon pulling over, I had no brake power, pedal felt hard and stiff; very little movement. Car had resistance during acceleration at this point as well.
Towed car home, left it on jack stands with no wheel. The problem right now is when I turn the car on and put it into DRIVE, the rotors won't spin at all. If I push on the brake pedal halfway, the rotors would begin to spin. If I continue to push on the pedal all the way, the rotors would stop. Any ideas people?
Here are the things I have tried:
-Took apart calipers and pads - looks ok, rotors appeared burned.
-Flushed and bled the system, went as normal; this made the pedals feel normal again(no more stiff pedal).
-Took calipers off (with brake line still attached) and attempted to push in piston with clamp: it will not go in at all.
-Took calipers off (with brake line still attached) and pump the brake pedal: piston moves out smoothly and freely, but cannot be pushed back in with clamps.
-Took calipers off (no brake lines connected) and attempted to push piston with clamp: piston moved smoothly and freely back in.
-Attempted to push rear caliper piston, spins freely but does not move back in.
Any suggestions are greatly appreciated. Thanks.
Could this still be a messed up caliper?
sugarloafpkwy
14
Dec 4, 2005 07:31 PM
RacerXintegra2k
Sep 25, 2002 05:03 PM
