trailing arm question
Old Jun 29, 2013 | 10:06 AM
89ED's Avatar
Default trailing arm question
is there a difference between 98 usdm teg and 98 jdm teg trailing arms
Old Jun 29, 2013 | 10:15 AM
POPLERO's Avatar
Default Re: trailing arm question
no? u mean stud wise
Old Jun 29, 2013 | 10:49 AM
89ED's Avatar
i have ef sedan and today i was read an old honda tech mag from 2005. it was an article with an ek and they were using 98 jdm teg trailing arms with prelude 11 inch rotors and acura legend calipers. i was wondering if i could use usdm trailing arms possibly DA ones and do this swap
Old Jun 29, 2013 | 01:36 PM
B_Swapped93's Avatar
so what exactly are you trying to do five lug prelude rotor ? just drill a lude rotor to a 4x100...
Old Jun 29, 2013 | 01:57 PM
89ED's Avatar
well i dont remeber any drilling in the article
Old Jun 29, 2013 | 02:05 PM
I'm STILL not sure what you're trying to do here. do you want 11'' rotors on your DA or DC more info is needed
Old Jun 29, 2013 | 04:18 PM
89ED's Avatar
in the article they used jdm (idk the difference between jdm&usdm) trailing arms from a 1998 teg, forth gen *vtec (it said vtec idk if it matters) prelude 11 inch rotors with acura legend calipers on and Ek chassis. i have an Ef chassis but * I AM WONDERING IF I CAN DO THIS ON MY EF*
Old Jun 30, 2013 | 08:34 PM
89ED's Avatar
bmp
Old Jul 1, 2013 | 05:26 AM
kyden's Avatar
there's no difference unless it's a type r. but if you're talking about 11 inch rotors and legend calipers, those go on the front and have nothing to do with trailing arms.
Old Jul 1, 2013 | 09:30 PM
89ED's Avatar
well idk i just read it. its from june of 2005 in hondatech magazine. maybe they used rear trailing arms because possibly DA rear trailing arms wont fit on the ek like they fit on my ef
Old Jul 2, 2013 | 01:28 PM
cvcrcr99's Avatar
Stop with the magazine quotes. They are only confusing everyone since you don't have links etc etc etc
What are you trying to install? Bigger brakes in general? Rear disc swap on your EF?
Old Jul 2, 2013 | 09:49 PM
89ED's Avatar
im just curious if i can do this to my ef sedan
heres the link it wasnt that hard to find *not that you were supposed to look*
just sayin
http://www.hondatuningmagazine.com/t...s/viewall.html
Old Jul 2, 2013 | 09:58 PM
slowDB7's Avatar
in the article you realize they are doing 2 different brake upgrades.
1st one, upgrading stock rear drum brakes to gsr rear disk brakes. by swapping the whole trailing arm
2nd, upgrading stock front to 11 inch prelude rotors with legend calipers. also this requires drilling of the prelude rotors cuz preludes bolt pattern is 4x114 and civics bolt pattern is 4x100
with that being said, the usdm and jdm gsr trailing arms are the same.
Old Jul 4, 2013 | 05:35 PM
89ED's Avatar
ok i didnt realize that but my ef already has DA rear disk* are gsr's bigger and can i put them on my ef
2nd fine i have to drill ok but can my ef knuckle be used and do the 2nd swap?
Old Jul 5, 2013 | 09:36 AM
cvcrcr99's Avatar
https://honda-tech.com/forums/honda-crx-ef-civic-1988-1991-3/88-91-crx-ef-civic-frequently-asked-questions-faqs-1508680/
FAQ page is stickied at the top of the 88-91 section. Look, they have a brake section.
Old Jul 5, 2013 | 10:15 AM
Decatur Racer's Avatar
You dont have to get prelude rotors and have them redrilled. You can buy 2008 mini cooper BASE rotors and they will go right on without redrilling because their 4x100. Also make sure there 280mm rotors for them to work.
Old Jul 5, 2013 | 12:28 PM
89ED's Avatar
& they are 11.1 inches?
Old Jul 5, 2013 | 01:53 PM
cvcrcr99's Avatar
https://honda-tech.com/forums/showthread.php?t=1508680
http://www.google.com/#gs_rn=19&gs_r...w=1366&bih=683
Not trying to be a dick, but this is all knowledge you can read up about.
Old Jul 5, 2013 | 06:05 PM
89ED's Avatar
i read it thanks. the fast brakes site has an adapter for 12.6 or 12.8 inch brakes. i dont see a write for those intentions
89ED
Jul 1, 2013 09:32 PM
ekBlackHatch
Apr 16, 2008 06:19 AM
Ricey McRicerton
16
Sep 9, 2004 08:46 PM
ham
May 22, 2004 09:06 PM
teger
Apr 16, 2002 10:49 AM
