ECU code 7 help!?...
Old Aug 3, 2006 | 02:36 PM
VTECth1s's Avatar
Default ECU code 7 help!?...
I saved myself $40+ from having to use a damn ecu scanner...did the DIY version
did it 7 times to make sure the code was consistent and the CEL code came up as 7(TPS) throttle position sensor. Now how do i fix this problem?, do i adjust it clock wise or counter? help!
Old Aug 3, 2006 | 04:04 PM
95 integra's Avatar
Default Re: ECU code 7 help!?... (egg6vtak)
Depending on what year you have, that more or less means the TPS is shot. Buy a used TPS sensor ($12 or so from what Ive seen) and have a good time getting the old one off or spend $50 on a used throttle body w/ sensors and replace the entire thing.
Old Aug 3, 2006 | 05:37 PM
VTECth1s's Avatar
Default Re: ECU code 7 help!?... (95 integra)
97 gsr...hmm which way is better and more convenient?
Old Aug 3, 2006 | 08:11 PM
95 integra's Avatar
Just buy a "new" used TB. The TPS has to be calibrated and isnt really easy to take out of the newer models (94+).
Old Aug 4, 2006 | 05:39 AM
VTECth1s's Avatar
any clue where I can find one? i assume autozone..etc would have them?
Old Aug 5, 2006 | 03:44 PM
95 integra's Avatar
classifieds or ebizzle.
thunderboy
Oct 16, 2008 11:14 AM
TegLove
Apr 23, 2004 11:24 AM
dabomb
Jul 14, 2003 10:15 AM
Rah Rah
Aug 9, 2002 06:17 PM
