which is more powerful
Old Aug 1, 2006 | 06:00 PM
Joeyt426's Avatar
Default which is more powerful
Which set up has more power, and which would be better to go with LS/Vtec w a b18A1 bottom and a B16 head or JDM GSR. Thanks for the help
Old Aug 1, 2006 | 07:45 PM
Ruben19's Avatar
jdm gsr
higher compression than ls/vtec.
im not a fan of ls/vtec
Old Aug 1, 2006 | 08:01 PM
vinai's Avatar
Default Re: (Ruben19)
Ls/V = more power, I agreee with rubin19 though not a fan. Get the gsr motor.
Old Aug 1, 2006 | 08:29 PM
AViciousTHRUST's Avatar
Default Re: which is more powerful (Joeyt426)
LsV w/ type r pistons ,or just a usdm GSR fck all this JDM motor, I'm a fan of JDM but not of the overpriced JDM motors
Old Aug 1, 2006 | 08:31 PM
j_DC2_m's Avatar
GO WITH GSR HAHA 180 HP AND I HEARD THAT LS VTEC MOTOR BLOWS AT SOME POINT. AND BOUT THE AMOUNT YOU GONNA SPEND ON A GSR PUT BOUT 500 MORE AND YOU LL GET A TYPE R
Old Aug 2, 2006 | 12:11 AM
davidluko's Avatar
Default Re: which is more powerful (j_DC2_m)
^^why do you find a need to respond to every post with all caps?
Old Aug 3, 2006 | 08:38 AM
VTECth1s's Avatar
As a fan of both ive been through 2 LS/V's and No problems whatsoever, ls/v's have much more power and more potential with the right build. I admire the Ls/v's and don't bag on them at all. Very fun! but I suggest GSR since vtec and everything else comes factory in the motor and has a redline of 8K+ with Ls/v's you need to build up to rev that high, thats if you plan on doing it, but its a honda thats what there made for ...if not built up to spec then your ls/v goes kaboom!.
Old Aug 3, 2006 | 08:47 AM
CleanLikeJdm's Avatar
Hype-R Stalker
Default Re: which is more powerful (Hatch_R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hatch_R &raquo;</TD></TR><TR><TD CLASS="quote">^^why do you find a need to respond to every post with all caps?</TD></TR></TABLE>
He obviously bought the caps only keyboard, look at his location.
I would just get an ls with boost, or a full GSR motor.
Old Aug 3, 2006 | 09:06 AM
H23 Power's Avatar
Default Re: which is more powerful (AViciousTHRUST)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AViciousTHRUST &raquo;</TD></TR><TR><TD CLASS="quote">LsV w/ type r pistons ,or just a usdm GSR fck all this JDM motor, I'm a fan of JDM but not of the overpriced JDM motors </TD></TR></TABLE>
wtf? jdm motors are usually the same if not cheaper than a similar USDM engine; not to mention they usually have about 1/2 the milage. And if there were no JDM engines then all the USDM engines (read limited supply) would be waaaaaay more expensive than they are now.
Old Aug 3, 2006 | 09:45 AM
teg91's Avatar
ls/v FTW!!
JesseBizz
19
May 21, 2009 05:49 PM
CR3X
Oct 26, 2007 05:43 PM
Dc4turbo408
Sep 9, 2004 06:58 PM
youngwon22
Oct 27, 2003 04:12 PM
ebelp
Mar 26, 2002 09:22 PM
