Overheated...HELP!
Old Aug 2, 2006 | 07:07 PM
latindc2's Avatar
Default Overheated...HELP!
So i decided to get my emission testing done today..when im driving to the testing station i there's a big splash on my winshield..Im like WTF? so i countinue not thinking nothing of it...when im at the line i get out of the car cuz i smell coolant and the tech guy tell me to pull it to the rollers and i was expletive i hope my car ok....so the roller spins....and smokes hissing out the cap and the tech guy says to shut it off and come again to retest so parked it out their testing place and pop the hood i though i just needed coolant...and i was fillin it with coolant I see this
so i just called the tow truck and had it tow to my place...
Do u guys think i fucked up my head??? and what guesses do u have that this couldve happend????
Old Aug 2, 2006 | 07:17 PM
Pnoyej6's Avatar
* B A N N E D *
whatthe hell happen to your upper radiator hose?
Old Aug 2, 2006 | 07:41 PM
latindc2's Avatar
Default Re: (pnoytegn707)
The rad hoses is still there....just my rad took a ****....
Old Aug 2, 2006 | 07:54 PM
jared99's Avatar
Default Re: (latindc2)
Head might be ok. Get the radiator issue fixed and run a compression test or see if white steam is coming out of the exhaust.
Old Aug 3, 2006 | 06:22 AM
latindc2's Avatar
Default Re: (jared99)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jared99 &raquo;</TD></TR><TR><TD CLASS="quote">Head might be ok. Get the radiator issue fixed and run a compression test or see if white steam is coming out of the exhaust.</TD></TR></TABLE>
Old Aug 3, 2006 | 07:16 AM
DC2 Mang's Avatar
did your temp needle ever go past the red?
and is there any smoking after the radiator has been replaced?
Old Aug 3, 2006 | 07:28 AM
DirtyBirdJR's Avatar
Default Re: (DC2 Mang)
that happened to me but i was in the drive thru beer store. radiators suck i have gone threw two
Old Aug 3, 2006 | 07:33 AM
crx_88_si's Avatar
just replaced mine too, never saw steam or anything, but could smell coolant, never got too hot either, just repalced it as a precaution.
Old Aug 3, 2006 | 11:02 AM
gsr dood's Avatar
Default Re: (crx_88_si)
ehhh....as long as ur needle wasnt on red for a long time....then i cant see how ur head would be messed up. plastic honda radiators take a **** often.
Old Aug 3, 2006 | 01:27 PM
eg4usdm's Avatar
Default Re: (DirtyBirdJR)
wait wait wait <TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DirtyBirdJR &raquo;</TD></TR><TR><TD CLASS="quote">that happened to me but i was in the drive thru beer store. radiators suck i have gone threw two</TD></TR></TABLE>
you have a drive thru beer store??
like you drive through and order beer?
omg if this is true.....
there will be a road trip in the making...
Old Aug 3, 2006 | 01:35 PM
Nors's Avatar
So water splashed up on your winsheild and you didn't think anything of it?
Am I the only person that finds that wierd?
Old Aug 5, 2006 | 10:43 AM
latindc2's Avatar
Default Re: (Nors)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Nors &raquo;</TD></TR><TR><TD CLASS="quote">So water splashed up on your winsheild and you didn't think anything of it?
Am I the only person that finds that wierd?</TD></TR></TABLE>
I thought it was waters from the street since it been raining here...yes the needle went all the way to the H!
Old Aug 5, 2006 | 10:46 AM
latindc2's Avatar
Default Re: (gsr dood)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gsr dood &raquo;</TD></TR><TR><TD CLASS="quote">ehhh....as long as ur needle wasnt on red for a long time....then i cant see how ur head would be messed up. plastic honda radiators take a **** often.</TD></TR></TABLE>
it was on red for a while...dumb me!!!
Old Aug 6, 2006 | 12:36 PM
CASTUDILLO01's Avatar
Default Re: Overheated...HELP! (latindc2)
replace radiator and done a leakdown test or compression test to see if any leakage is occuring if so replace the headgasket. if so do the waterpump,timing belt and drive belts and thermostate and gasket because you overheated the motor.
Old Aug 6, 2006 | 03:44 PM
.BULLET.'s Avatar
From: kapalua,los angeles,las vegas, HI,CA,NV, United States
Default Re: Overheated...HELP! (CASTUDILLO01)
wow..replace all thats necessarry...ive seen this problem in traffic quite a few times.
Old Aug 7, 2006 | 04:14 PM
LatinEM2's Avatar
So we replaced the radiator..filled it with Type 2 coolant..and its still overheating...the needle goes up...the fan didn't turn on while idling in the garage...but both fans turned on when my bro turned the A/C on.
Old Aug 8, 2006 | 08:32 AM
latindc2's Avatar
Did a compression test and the results
cylinder 4= 205
cylinder 3= 205
cylinder 2= 200
cylinder 1= 200
ima go change my thermostat now....wish me luck
67mmlsv
Apr 22, 2014 09:32 AM
96WhiteOnBlack
Apr 5, 2007 08:01 AM
jardolei
Jan 19, 2007 11:47 PM
huepowered
Feb 15, 2006 04:51 PM
89s1
Sep 10, 2004 08:40 AM
