Does "O2 Sensor Heater" CEL code...effect my performance?
Old Aug 3, 2006 | 06:46 PM
mxl36o's Avatar
Default Does "O2 Sensor Heater" CEL code...effect my performance?
After extended the O2 sensor wire, a CEL light appeared code 41 (O-2 Sensor Heater ). Anyone know if this will disable the vtec or cause me to be less fuel efficicent
Old Aug 3, 2006 | 07:40 PM
Nors's Avatar
Default Re: Does "O2 Sensor Heater" CEL code...effect my performance? (mxl36o)
I am not sure, I believe it heats up the o2 sensor when the car turns off the burn the carbon or whatever else is built up on the o2 sensor.
Old Aug 4, 2006 | 07:35 AM
Nors's Avatar
Default Re: Does "O2 Sensor Heater" CEL code...effect my performance? (Nors)
Actually come to think of it, I think it heats the o2 sensor up when the car is cold to get a more acurate reading.
Old Aug 4, 2006 | 06:08 PM
Smog09's Avatar
No it has nothing to do with performance. When your car is cold it's in open -rich,meaning the o2 sensor does'nt work till your car is warmed up(closed loop). The heater helps the o2 go into closed loop so it will be close to Stoich. 14.7:1.
Old Aug 4, 2006 | 06:09 PM
Smog09's Avatar
No it has nothing to do with performance. When your car is cold it's in open loop -rich,meaning the o2 sensor does'nt work till your car is warmed up(closed loop). The heater helps the o2 go into closed loop so it will be close to Stoich. 14.7:1.
4tika4
Jul 25, 2009 05:23 AM
importdreamer
May 26, 2007 06:58 PM
Phoenix_ITR
Jul 9, 2003 04:21 AM
agent marlon
Jan 29, 2003 01:22 PM
