swapping cams?
Old Aug 11, 2006 | 09:04 AM
94b16teg's Avatar
Default swapping cams?
I have a b16 and i got gsr cams and i wanted to know the easiest way to install them any advice would great thanks.
Old Aug 11, 2006 | 09:11 AM
lVlemphizStylez's Avatar
Default Re: swapping cams? (94b16teg)
remove valve cover...remove dizzy...remove cam caps and plates in sequence...slide the cams out...Impact wrench to remove the bolt that holds the cam to the cam sprocket
Reinstall new cams on sprocket, untension timing belt, set cams to TDC etc etc etc (while the crank is at TDC of course) install cam caps and plates and dizzy. Retension belt
EF'GSRrr91
12
Sep 18, 2014 06:59 AM
MurtazaDSM
Apr 14, 2012 05:50 AM
LSTurbo23
Oct 22, 2011 08:13 AM
Twigster311
Jul 5, 2003 09:17 AM
2fknlo
Apr 1, 2002 06:40 AM
