compression problem
Old Aug 13, 2006 | 08:13 PM
94_T3G's Avatar
Default compression problem
i just did a compression test on my integra and the numbers were 200,100,150,160. What do u think would be teh problem and is it worth it to fix it now because im gonna get a new engine within the next couple monthes anyways. Right now i have the ls engine and im getting the gsr engine i think.
Old Aug 13, 2006 | 08:26 PM
unknown0001's Avatar
Default Re: compression problem (94_T3G)
it might be your piston rings that arent sealing well
do you blow out any oil or blue smoke out your exhaust on idle or when your reving it?
Old Aug 13, 2006 | 08:30 PM
94_T3G's Avatar
Default Re: compression problem (Mr.RHTuner)
no it doesnt have any problems when i bring it up to 6k rpms and thats the highest i ever take it.
Old Aug 13, 2006 | 10:51 PM
bennyDA's Avatar
Hey sorry cant help yah lol
But how/where did u do a compression test, I need to do one before I think about saving for boost
(yes im a newbie)
Old Aug 13, 2006 | 11:02 PM
RandomTask76's Avatar
Were you at wide open throttle during the comp test? The fact that you have poor numbers next to each other can indicate a bad head gasket...maybe test again at wide open throttle with all 4 cylinders..then..
The next step is to add a cap (from a bottle of oil) full of oil to each cylinder about a minute before you test it (wet compression test)...if the comp goes up significantly, you have a problem with your bottom end in that cylinder (broken ring landing, etc.)...if not, the problem lies somewhere in your head (bent valve, etc.)...
You can also check for blow-by (pull off vacuum hose off of the valve cover and look for mist coming out)...if you have blow by it's a piston problem (ring landing, ring, etc..)
If you're about to replace the motor anyway I wouldn't bother dealing with the problem after you figure out what it is, it will probably be just fine for the next couple months...good luck
Modified by RandomTask76 at 9:40 AM 8/14/2006
Type 56
Oct 12, 2016 11:10 AM
66fasty
May 7, 2008 12:50 PM
climb_on
Jul 29, 2007 03:40 PM
John.
Jun 12, 2006 08:45 AM
