HID question! please help
Old Aug 12, 2006 | 04:39 AM
msbhvn_DC2's Avatar
Default HID question! please help
ok guyz, i just picked up a set 4300K HID and i just had it installed. the problem is the driver side (USDM 98 front), is slightly yellowish compared to the passenger. it drives me freakin crazy! i thought something was wrong with the kit, but i switched the passenger side to the driver side and vis versa...... the driver side was still yellowish. what do you guyz think it is? you think i should just go to my local acura dealership and purchase another driver side headlight housing? any help would be greatly appreciated, thanks in advance.
Old Aug 12, 2006 | 07:52 AM
Ichigo's Avatar
there are some stuff at advance auto parts or checkers that you can use to clean up your headlight. Its probably just dirty.
Old Aug 12, 2006 | 12:36 PM
msbhvn_DC2's Avatar
Default Re: (Ichigo)
have you ever cleaned the insides of a headight before?
Old Aug 12, 2006 | 01:01 PM
teknoracing's Avatar
Default Re: (msbhvn_DC2)
no man, you rub that stuff on the outside of the lense. I suppose you can clean the inside too, ive used chopsticks and toilettes.
Old Aug 17, 2006 | 08:37 AM
JdmTypeRdc2's Avatar
it could be dirty but sometimes( like many OEM hids do) they look a little yellowish depending on the angle ur looking at it. mine had the same thing. my headlights werent dirty...after a while when the bulbs are starting to get more wear into them...the colors will match up and actually turn bluer. in the beginning they look yellow but over time they will clear up and turn white/blue...happened to me...nothing to worry about...
btw 4300k is not pure white...its supposed to have a yellowish tint to it...thats why...if it was a 6000k then it would be more white.
Old Aug 17, 2006 | 09:32 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: (JdmTypeRdc2)
4300K is not yellow, maybe just a touch when new but for the most part they are pure white, slightly blue-ish. That's how mine are. 6000K is straight blue and ghey as hell
Old Aug 17, 2006 | 09:35 AM
Lewie's Avatar
I'm here for the gangbang!
Clean the outside first, there's a kit you can pick up at the local auto store.
Old Aug 17, 2006 | 09:36 AM
if u read my post i said "a tint of yellow at angles" and its true...just like oem hids...they can give out different colors when looking at them different ways....and yea 6000k are gay but theyre more white/ blue than 4300k...the best thing is retrofit...with tsx projectors but itll be a little more costly than just a plug and play kit.
Old Aug 17, 2006 | 09:37 AM
Community Builder
stock halogen projectors don't put out any color, though, like the blue color band at the edge of the cutoff you get with HID projectors.
Old Aug 17, 2006 | 09:45 AM
very true cuz when i had my stock halogen projectors...i noticed that..however the color that is viewed can sometimes vary on either...with my tsx projectors i notice that sometimes it gets yellow depending on the way i look...people sometimes ask me if i got my hids stolen...lol but its just the way the light output is seen,...against the wall, the cutoff is full of color
Old Aug 17, 2006 | 10:08 AM
pat.ter.rick's Avatar
Default Re: (PatrickGSR94)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PatrickGSR94 &raquo;</TD></TR><TR><TD CLASS="quote">4300K is not yellow, maybe just a touch when new but for the most part they are pure white, slightly blue-ish. That's how mine are. 6000K is straight blue and ghey as hell </TD></TR></TABLE>
uhh no.....6000k is not straight blue..cuz my HID's are 6000k and it is WHITE!
Old Aug 17, 2006 | 10:27 AM
Community Builder
umm yes... okay maybe not straight blue, but the light it puts on the ground is more blue than my 4300K which puts white light on the ground.
I will always hate on anything over 4300K. That's just me. Don't take it too personal
Old Aug 17, 2006 | 10:28 AM
Lewie's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PatrickGSR94 &raquo;</TD></TR><TR><TD CLASS="quote">I will always hate on anything over 4300K. That's just me. Don't take it too personal </TD></TR></TABLE>
12000K FTW
Old Aug 17, 2006 | 10:29 AM
Community Builder
I see wayyyyy too many aftermarket HID setups around here and every one of them is pure junk. I hate on every single one of them.
4300K in retrofitted HID projectors is the ONLY way to go that is worth a damn IMHO.
Old Aug 17, 2006 | 10:36 AM
AwOrKiNpRoGrEsS23's Avatar
just curious, what brands are you guys running and are you happy with them? cause i'm thrownin in HIDS in my DC2 soon and i wanted to see what everyone thought of the different brands and such...thanks
Old Aug 17, 2006 | 10:49 AM
like patrickgsr said before...The ONLY way hids look and perform the best in an integra is a retrofit...u cannot get better than that...so my advice is to not spend money on plug and play kits because theyre not worth the 300 or whatever dollars people pay for them...just buy a set of tsx projectors with 4300k bulbs, ballasts and connectors and wire it up...u can def see the difference in light output...OEM is best...
Old Aug 17, 2006 | 07:28 PM
hmm ok i might just have to check into that more i guess...i just know that the stock dc2 projectors suck *** and i drive a lot so it's nice to have some good light without blinding the **** out of people with my high beams
Old Aug 17, 2006 | 07:33 PM
rufridn's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PatrickGSR94 &raquo;</TD></TR><TR><TD CLASS="quote">4300K in retrofitted HID projectors is the ONLY way to go that is worth a damn IMHO.</TD></TR></TABLE>
what i have
Old Aug 17, 2006 | 08:27 PM
calxtreme's Avatar
Have you thought to see if the lights are level? Because if they aren't you might be seeing more of the color from the color of one light than the other.
kyw3
Jan 4, 2009 04:32 PM
B18C R Spec
Oct 31, 2005 12:28 PM
yesbuy
Dec 27, 2003 08:09 AM
Banned Poser
18
Oct 22, 2003 08:57 AM
bryant
Mar 13, 2003 06:58 PM
