Fuel rail problems?
Old Aug 12, 2006 | 05:07 PM
KArowd's Avatar
Default Fuel rail problems?
Quick Q: What are the signs of a "bad fuel rail" ? My problem i have now is it seems like my car is trying to suck gas and it putters and loses rpm. the rpm meter bounces around between 3-4k. I dono what it could be.
Old Aug 12, 2006 | 09:55 PM
lsvtek's Avatar
Default Re: Fuel rail problems? (KArowd)
IVAC maybe?
Old Aug 12, 2006 | 10:16 PM
qfast817's Avatar
Default Re: Fuel rail problems? (4drlsintegra)
fitv or a vac. leak
liftandcut's Avatar
Sometimes when you get work done on your car, the mechanic may accidentally hit an alternator wire and loosen it. My car was sputtering and power through the gears was inconsistent. My mechanic took it for a test drive and figured it out immediately. It might be worth checking yourself or at a mechanic because it's cheap to diagnose and to fix. Good luck.
CimorelliCRX
Apr 7, 2022 12:16 PM
endwell17
Sep 25, 2011 06:31 PM
GuCBlackEk
Apr 9, 2010 07:23 AM
Clipsed
Mar 25, 2008 06:33 AM
ser13
Feb 6, 2007 06:00 PM
