Golden Eagle VTEC conversion kit quality?
Old Aug 13, 2006 | 12:20 PM
jman86's Avatar
Default Golden Eagle VTEC conversion kit quality?
Hey guys, Im looking to order the golden eagle VTEC conversion kit, and i was wondering if anyone has gotten one before.
I just wanted to know how the quality of the parts are and also how good is the Head Gasket.. I dont want to order it if it is a cheapo gasket..
Thanks for the info..
JMAN
Old Aug 13, 2006 | 12:28 PM
-Darren-'s Avatar
bump for answers
Old Aug 13, 2006 | 01:12 PM
cm zak's Avatar
There are higher quality gasket, but it is a very reputable conversion kit, as long as you are like revving to 9k or something i wouldn't see it as a problem. Just don't be stupid.
Old Aug 13, 2006 | 01:16 PM
doood's Avatar
been there done that
Default Re: (cm zak)
isnt the hg in the kit just a modified oem hg?
Old Aug 13, 2006 | 02:04 PM
Dartanian's Avatar
Default Re: (sticky icky)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sticky icky &raquo;</TD></TR><TR><TD CLASS="quote">isnt the hg in the kit just a modified oem hg?</TD></TR></TABLE>
It is.
Golden Eagle makes high quality parts. I am using a few of their parts and haven't been disappointed yet.
Old Aug 13, 2006 | 08:12 PM
jman86's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cm zak &raquo;</TD></TR><TR><TD CLASS="quote">There are higher quality gasket, but it is a very reputable conversion kit, as long as you are like revving to 9k or something i wouldn't see it as a problem. Just don't be stupid.</TD></TR></TABLE>
Ok so if i get this kit i shouldnt rev past 9k?...even the block is built for it.... i really dont plan on going more than 9500 or so....
what are some other companies that make a gasket that will work for the lsvtec...or would i just have to buy a gasket and drill the dowel holes?
thanks,
JMAN
Old Aug 13, 2006 | 08:30 PM
Dartanian's Avatar
Default Re: (jman86)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jman86 &raquo;</TD></TR><TR><TD CLASS="quote">
thanks,
JMAN</TD></TR></TABLE>
You can rev to 9k if the motor is built for it. There is no question that Golden Eagle makes quality parts that can withstand a good amount of abuse.
You can modify a stock gasket to accomodate wider dowel pins with a drill press.
Old Aug 14, 2006 | 07:15 AM
jman86's Avatar
Default Re: (Sleeper Style)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sleeper Style &raquo;</TD></TR><TR><TD CLASS="quote">
You can modify a stock gasket to accomodate wider dowel pins with a drill press.</TD></TR></TABLE>
So ill be alright if i rev to no more than 9500...
The motor is completely built....w/ darton sleeves, je pistons, eagle rods, stock crank, clevite bearings, type r head, with skunk 2 valves, spring and retainers. about to get skunk 2 stage 2 cams i think..or i might just get some stock type r cause i plan to go turbo eventually..just need more $$$...
Old Aug 14, 2006 | 07:44 AM
skunked's Avatar
GE
Old Aug 14, 2006 | 09:09 AM
aznsins88's Avatar
if your motor can handle the abuse than keep reving its just that some people do the ls/vtec swap with a gsr head and think that their block can handle the 8000rpm revs and then blow something but if your motor is build....VTACK!
Old Aug 14, 2006 | 09:50 AM
gsrtim's Avatar
I have had great luck with my kit.
Old Aug 14, 2006 | 10:09 AM
jman86's Avatar
Default Re: (gsrtim)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gsrtim &raquo;</TD></TR><TR><TD CLASS="quote">I have had great luck with my kit.</TD></TR></TABLE>
What type of setup do you have and how much do you rev to?
Old Aug 14, 2006 | 10:17 AM
Slammd Sol's Avatar
Using one in my setup. Quality stuff
eh2_erik
Nov 5, 2013 11:25 AM
dcteg
Jun 29, 2005 04:49 AM
ReV LiMiT
Apr 29, 2005 01:18 PM
253EK
16
Jun 5, 2004 05:57 PM
253EK
Mar 2, 2004 07:46 AM
